Hard Start
Old Feb 28, 2004 | 11:16 PM
LOW TRAC's Avatar
Hard Start
Alright, this has happened a few times now and has me stumped. Every once in a while, I'll roll the car over a couple times and then tap the gas in anticapation of a start. Problem is it dosen't start on that try and what follows is mystifying. I have to crank the hell out of the car to get it started and it only starts while holding the pedal to the floor. Once it starts its really rough untill it passes about 2500 rpms. Every time this happens I'm on my way to school or work so theres not an opertunity to let it sit and see if it helps. I haven't noticed any other symptoms and there seems to be no other factors as far as weather or parking angle.
Has anybody had this problem before? Is this possibly my Optispark starting to crap out? I dont freakin know and since its a fairly rare I'm not that concerned......yet. Anyway, any help as always would be apreciated.
Old Feb 29, 2004 | 12:34 PM
OBE1 95Z28's Avatar
About twice a year I have the same thing. It acts like it's flooded, but the car has set for 2 days before starting. I don't tap the gas in anticipation of it starting, but I do have to hold the pedal to the floor to get it too start (after much cranking). I haven't found the cause either since it happens so rarely. I've speculated that it could be the carcoal canister dumping fuel into the system but you would think it would happen more often if this was the case.
Old Feb 29, 2004 | 01:34 PM
Montezuma's Avatar
Mine used to take 4-5 seconds to start but after replaceing the ignition coil it took about a second and half. You can get one for $20 at an auto parts store. I would try that first.
armedtrigger
Feb 24, 2015 08:30 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
