This Is Hard To Explain
Ok I'm going to try my best here.
I am wondering if my clutch is slipping, (i know this sounds dumb) but i really can't tell with my car. some times on the road when i give it off a light the rev's go right up. I kind of feel that the car is spinning the tires but i'm not sure. I can rip it hard into gear and it's fine no slipping there. i would think if it were to slip at all it would come in hard gear changes.
I can chirp my tires into 3rd gear is that normal for this car?
well mine didn't give any signs, except once in a while it would grind as I released the clutch usually in first gear. I did notice that the clutch engaged right at the top of its travel, I mean there was practically no difference between engaged an not, so you can check your that way. Mine I could also rip 3rd gear, and when I pulled the clutch the material was almost all gone it was starting to scrape on the rivets
