This happens only when I drive for the first time of the day...
Old 06-07-2004, 08:36 AM
ping0317's Avatar
Exclamation This happens only when I drive for the first time of the day...
Every morning when I start to drive, I press on the gas(1/4 down) and I feel my car hesitating for a while and the hestitating stops and I feel my car releasing the power it was holding back. And the more I drive, the hesitatiion disappears.
Do you know what is going on? My last modification was my 2400-2800 TCI Torque Converter and before that I replaced my spark plug, spark plug wires and opti too.
ping0317 is offline
Old 06-07-2004, 09:35 AM
LT1ponykilla's Avatar
My car seems to be doing the same thing. This didnt start until I put the new exhaust system on.
LT1ponykilla is offline
Old 06-08-2004, 03:09 AM
BigBlue95Z's Avatar
Is there any white smoke coming out of the exhaust?? When head gaskets start to go the leak a little bit of fluid in the chamber then will clear out and be fine until it sits for an extended period of time.....just a thought and a quick check...
BigBlue95Z is offline
Old 06-08-2004, 07:26 AM
ping0317's Avatar
Is that leak bad for our car? Is there another way to check for that issue or do I need to ask someone to follow me around when I am driving to verify the white smoke status...
ping0317 is offline
Old 06-08-2004, 09:17 AM
DonHood's Avatar
Blown headgaskets are bad leaks on any vehicle. Just crank it up and walk out behind your car to check for the white smoke. Might also pull of your radiator cap when it's cold, then crank it up. If you see little bubbles coming up, you're gonna be in for some pricey repairs.
DonHood is offline
Old 06-08-2004, 03:42 PM
ping0317's Avatar
thanks! Going to do that today. I hope those symptoms don't show up!
ping0317 is offline
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
Feffman
10-09-2015 05:42 AM
jb4xx
02-02-2015 10:00 PM
bw_hunter
12-25-2014 11:57 PM
Quick Reply: This happens only when I drive for the first time of the day...
