Hal shock install questions and tips.
Old Mar 8, 2004 | 06:14 PM
94foormula's Avatar
Im going to be installing the Hal Qa1 shocks soon and had a couple questions. I read Fred's guide so I have a pretty good idea on to do most of the work.
1. Do I need to modify the spring seat if Im using both the Hal shocks and springs?
2. Are there any tips and tricks you guys have discovered before I set out to do this?
Old Mar 8, 2004 | 06:24 PM
1. Hal springs are smaller in diameter and don't need the stock spring seats-so no modifying necessary.
2. I think Fred covers most everything in his write-up.
Old Mar 9, 2004 | 12:37 AM
OBE1 95Z28's Avatar
The ride height adjustment is really hard to do (tight - binding) unless you either put antisieze grease between the washer and the adjustment ring or place a bearing above the adjustment ring.
Old Mar 9, 2004 | 07:07 AM
HungryT/A's Avatar
No modification required, the HAL springs fit perfectly on the HAL shock retainers. I was just using grease on the threads and ring, took the spanner wrench and gradually compressed the spring.
Some notes to Freds write-up:
Forget the lower balljoint, just separate the upper joint, it's much easier. Unbolt the nut, and tap it with a hammer. Be ready to catch the spindle if you have not removed the caliper...
It's a pretty straightforward project IMHO.
Old Mar 9, 2004 | 10:02 AM
OBE1 95Z28's Avatar
I found that greasing the threads didn't help, the thin washer that sits on top of the adjustment ring binds against the adjustment ring; grease this interface and adjustment is now easy.
Old Mar 9, 2004 | 10:37 AM
QA1 has a roller thrust bearing that can replace the thin washer. It should make adjustments a lot easier.
Old Mar 9, 2004 | 10:49 AM
LT1TONY's Avatar
I'd make sure to use the thin roller bearings. This will make it easier to turn.
Old Mar 9, 2004 | 11:52 AM
94foormula's Avatar
Thanks for the tips guys. Ill make sure to get one of the roller thrust bearings.
Is this a QA1 specific part?
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
tubby
Oct 13, 2003 09:16 AM
Chrisdude
Jul 24, 2002 02:25 PM
