h/c or boost
Old Feb 4, 2007 | 10:21 PM
  #31
526 SS 96's Avatar
A good cam and head kit on a stock short block can easily run mid/low11's. A good cam only car can get 12's. A good N/A engine can get you 10's. All of the options, with exception of the last one, are less money to build and tune than a bolting on supercharger kit to a stock engine. They will also be more reliable, assuming that it was built correctly. Blower cars are sweet, don't get me wrong, but it seems (according to your post) that you don't have the budget for a properly set up one. Blowers are best saved for cars that have a budget for a forged short block and more than a few hours of tunning time.
Old Feb 5, 2007 | 05:42 AM
  #32
12345678910's Avatar
i was going to spend 2800 for everything. and with the supporting mods that a cam needs its about the same even if i went with an le1 setup and that would only be 370 rwhp and blower at 8 psi probaly 420 rwhp but i dont want to blow the motor so i gues ill have to think about it thanks for all our opinions
Old Feb 5, 2007 | 03:20 PM
  #33
SantaCruz163's Avatar
I've always said this and I'll say it again; With the stock compression of the LT1 at ~10.5 it is not worth running a supercharger at ~6psi. You will end up spending more, you see around the same power gains as a stout H/C combo and you're at risk blowing up the engine. Now, if you were going to do a forged/low CR short block then I'd say boost the hell out of it. But stock LT1s were not made for boost.
Old Feb 5, 2007 | 04:01 PM
  #34
so maybe h/c then
Old Feb 5, 2007 | 05:32 PM
  #35
dre2013's Avatar
h/c...maybe a lil giggle juice
Old Feb 5, 2007 | 07:48 PM
  #36
hulettsz28's Avatar
i would go with boost. just dont get carried away with it, and know that a rebuild will be coming. i was in the same situation, le1 heads/cam or boost. i bought my procharger used on here with injectors and some upgrades what not for $2000...so its really not that expensive considering you put it on yourself. plus down the road you can just slap a different pulley and up the boost, a s/c is just more capable in the long run.
Old Feb 5, 2007 | 08:57 PM
  #37
how long did your motor last and how much boost did you run
Old Feb 6, 2007 | 09:24 PM
  #38
anyone know what pullies to run to get 6psi of boost on a p600b
Old Feb 6, 2007 | 10:59 PM
  #39
breakmyfootoff's Avatar
I could be wrong, but I believe that would be the 3.3 inch blower pulley with the 6 inch crank pulley.
Old Feb 8, 2007 | 08:26 PM
  #40
anyone else have a boosted lt1 need to know hoing to buy procharger tomorrow
Old Feb 8, 2007 | 08:51 PM
  #41
joe-96z1le's Avatar
If you're buying a new kit, ProCharger can spec a pulley size. But, on a stock LT1 engine, you're looking at a s/c pulley size around 3.25" for 6-7lbs. of boost.
Old Feb 8, 2007 | 08:53 PM
  #42
slp97camaro's Avatar
i was going to go w/ boost on my car, but then i was concerned about the bottom end. im now going with H/C, and maybe a little spray once in a while...i guess its all what you want though...like everyone else has said if your going boost, make sure you start saving up for the bottom end!
Old Feb 8, 2007 | 08:56 PM
  #43
but also...if you do blow the bottom end, and you do have the money to fix it...you will be ahead with already having the charger...then you could boost the **** out of it....so idk
RUENUF
Mar 13, 2016 03:37 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
96SilverRam
Sep 7, 2015 10:51 PM
Henson071
Aug 4, 2015 09:32 AM
