? for guys xe grind cams
Old Feb 11, 2004 | 05:15 PM
ltwonz's Avatar
I ordered a XE 224/236 cam from thunder racing and when i got the cam it cam in a XE box turned inside out. It also didn't come with a cam card or any kind of lube. My question is shouldn't it have these other items because how do i know for sure what I have. I tried e mailing Thunder racing a couple of weeks ago with no response. thanks for your guys help.
Old Feb 11, 2004 | 05:35 PM
Beast96Z's Avatar
What are the numbers on the back of the rear cam base? It should read 3314/3316HR114+4 This is assuming you got a 114 LSA and Thunder ground 4 degrees of advance in.
Old Feb 11, 2004 | 05:40 PM
ltwonz's Avatar
I will have to check later the cam is at my house and i'm at work.
Old Feb 11, 2004 | 07:29 PM
ltwonz's Avatar
ttt Anyone else?
Old Feb 11, 2004 | 08:50 PM
besz28's Avatar
you know what mine came the exact same way,and i get a little nervous like what if it isn't the cam i wanted.i just have to trust them...
Noenav
Mar 1, 2019 07:38 AM
Cam's maro
Jan 30, 2015 09:21 PM
chuyz28
Nov 25, 2014 11:14 PM
Red97LT1
Aug 7, 2002 05:45 PM
