Guys who change injectors.........
Old Oct 5, 2003 | 09:06 PM
S.J.S.'s Avatar
I got a set of Bosch 30# injectors and was looking at the difference between the Bosch and the stock ones. The Bosch ones appear to be a lil longer and got that extra plastic tips on the end that goes into the manifold. It looks like it would impeded airflow. Anyone know if these will do? I was told the Bosch ones fit.
Old Oct 5, 2003 | 09:13 PM
RamAir95TA's Avatar
Are you sure the plastic caps aren't for protection during shipping?
Old Oct 5, 2003 | 10:45 PM
S.J.S.'s Avatar
Aw cummon man...gimma some credit. Buildin my own motor I know a plastic cover when I see one. ahahahha. anyway no..I'm talking about the nipple part. The stock injector doesn't have it. Here look there just flat on both sides the stock ones.
http://cgi.aol.ebay.com/ebaymotors/w...tem=2434593983
Old Oct 5, 2003 | 11:01 PM
The pintle style injectors (Bosch, Denso, FMS, SVO, etc) are prone to "carbonizing" the tip where the pintle sticks out. The little plastic caps help shield the tip from the heat of an open intake valve on shutdown. If you look at the way the injector sits in the intake manifold, the tip does not stick down into the air runner. Look at the upper left part of this picture and you can see where the tip of the stock injector sits, about 1/4 - 3/8" away from the runner.
Old Oct 5, 2003 | 11:09 PM
S.J.S.'s Avatar
Thanks a lot Fred....I was hoping someone you'd jump in and let me know before I put this bad boy together.
Thanks again
Old Oct 5, 2003 | 11:15 PM
I run 64# Bosch injectors @ 58psi (=77.8#/HR)..... they work just fine .
Old Oct 5, 2003 | 11:56 PM
AsianSensation's Avatar
Sweet Jesus. 64#......
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Sergio
Jan 27, 2016 04:27 PM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Red97LT1
Aug 7, 2002 05:45 PM
