Guys whats wrong with my car? I'm about to cry
Old May 24, 2003 | 05:05 PM
irocdreamer's Avatar
Unhappy Guys whats wrong with my car? I'm about to cry
Ok, my starter has been slowly dyeing for awhile now. Last night my car would not start. Righ when you turn the key it would begin to turn over then stop completly, not turning over at all. Today i changed the starter %100 sure that was the problem. Wrong. It does the same thing. I am at a complete loss here. It drove home absolutly fine, then I was going to get something to eat but didn't start. I am beginning to hate this car. Any thoughts?
Old May 24, 2003 | 05:27 PM
cals400ex's Avatar
test the battery. mine was doing the same thing.
Old May 24, 2003 | 05:32 PM
Done that, didn't help.
Old May 24, 2003 | 05:51 PM
ANYONE?
Old May 24, 2003 | 05:55 PM
Phatcaprice's Avatar
1. Test the alternator.
2. Check out the BIG battery cables. Check for corrosion on the wires, ground and positive. Check the little solenoid wire too.
Old May 24, 2003 | 06:01 PM
ba96ta's Avatar
Does it make a clicking sound when the starter stops?
Check grounding on it
Old May 24, 2003 | 06:02 PM
I thought the alternator had nothing to do with the car starting? I had it tested a week or two ago, it was fine.
Old May 24, 2003 | 06:04 PM
Rodrigues's Avatar
Have you COMPLETELY tried a different battery? Also, do you hear the relay clicking?
You're right, it doesn't. But maybe the alternator isn't fully charging your battery. Leading to poor cranking power.
Old May 24, 2003 | 06:32 PM
I put my dads battery in it and it did the same thing. There is no clicking whatsoever, just the motor turns 1/4 of the way then stops. Nothing. No complete rotation, doesn't even have a chance to catch.
Old May 24, 2003 | 07:37 PM
FuryZ28's Avatar
does it just lock up? or does it turn a 1/4 way & then you can hear the starter gear spin...maybe some chipped teeth off the flywheel/flexplate?
Old May 24, 2003 | 07:43 PM
bunker's Avatar
Check for good ground & make sure power isn't grouding out anywhere. Also could be your opti
Old May 24, 2003 | 08:39 PM
It locks up. Sounds like it engages, then locks up. I havent' noticed any misses or anything, and like I said, it ran fine on the way home. But those optis do suck.
Old May 24, 2003 | 08:48 PM
FastZinTennessee's Avatar
Hmmmm, mine does this- (sometimes) get in the car to start it, put key in ignition, turn key to crank position and hear a click, but no turn of the motor. Back key out of ignition, repeat process, again click but no turn. The clicking is coming from under the hood. Where is the starter soleniod on these cars, I think that might be the problem.
John
blac94Z
Dec 2, 2014 12:09 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
USAirman93
Nov 24, 2014 03:37 PM
Red97LT1
Aug 7, 2002 05:45 PM
squirrels
Jul 13, 2002 01:58 AM
