guys w/3.73's, got a question
Old Jul 1, 2004 | 02:09 PM
street demon2k3's Avatar
my bro has a 94 Z and he has 3.73's but hasnt gotten his car programmed for the gears. on the 2-3 shift it hits the rev-limiter and he has to get off the pedal. my question is since the trans isnt programmed, can he just manually shift at the track without hitting the lmiter? thanks in advance
Old Jul 1, 2004 | 02:46 PM
Sweetred95ta's Avatar
Nope. Sorry, if it hits the rev-limiter in drive, it will do the same manually shifting it. When the tranny's are stock, even if you hold it out in gear, it will shift itself. Atleast mine did. Get it programmed and hopefully that is the extent of the problem.
Benji
Old Jul 1, 2004 | 03:17 PM
CrockRocket94's Avatar
I had that same problem..
turned out my tranny was going bad
It pegged the rev limiter at WOT....
took about 1 yr for the tranny to totally start slipping especially in 4th gear.
sscott
Jan 17, 2015 04:30 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 27, 2014 10:06 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Red97LT1
Aug 7, 2002 05:45 PM
