Guys with SLP headers...
Old Feb 20, 2004 | 09:54 PM
Cmr0z28's Avatar
I'll be getting 96-97 shorties real cheap. They were shipped today, and when I get them I'm sending them out to be coated. I'm most likely going with a stainless works catless Y pipe, and I know the fitment isn't great, but that's what sawzalls are for
Anyways, how's the install on these? How is plug access? Any tips on the install? Sound clips anyone?
-Matt
Old Feb 21, 2004 | 12:15 AM
S.J.S.'s Avatar
Put mine on when I rebuilt my motor. With the motor on the hoist I still had a difficult time getting them in. You will have to unbolt the motor mounts and jack the engine just to get the stock manifold out. But all in all I like them.
Old Feb 21, 2004 | 09:59 AM
Cmr0z28's Avatar
Ok thanks, anyone else?
Old Feb 21, 2004 | 01:31 PM
stereomandan's Avatar
Really? I've never seen that you have to jack the motor up to get the maniforld out. What caused you to have to do this? I'm curious because I have a '97 and will be taking the maifolds off this spring.
Cmr0z28,
Here are some links to header install sites. They aren't SLP's, but it may give you a idea of what to watch out for.
http://www.fastblackcar.com/camaro/mac_headers.html
http://ken.lowrance.com/Projects/Hea...derInstall.htm
http://www.go-fast.org/z28/headers.html?
Dan
Old Feb 21, 2004 | 01:55 PM
SlickBlack Z's Avatar
You wont have to jack up the motor to get the stock exhaust manifolds out.
Old Feb 21, 2004 | 03:03 PM
fastbird96's Avatar
You DON'T have to jack up the motor to remove the manifolds OR to install the headers.
The drivers side is a piece of cake.
The passenger side requires a little more effort and it's best to have someone help you.
Plug access is about the same. Maybe even slightly easier. The only difficult time I had during the install was getting the y-pipe to line up.
Old Feb 21, 2004 | 03:43 PM
Cman's Avatar
plug access with SLP d/c headers isn't too bad if you know how to get at them. I did my plugs back in Dec. when I put my Formula up on stands for the winter. The only thing I had to do was move the starter and remove the AIR fitting on the pass. side that screws into the fitting on the header, that's it. I didn't have to unbolt the exhaust at all. Most of all have the patience and the right tools to do the job.
here's a link to my plug install:
http://www.ws6zxr.com/showthread.php?s=&threadid=26334
I have some other posts here re: the headers and how to install them, do a search under my username and you'll find them. Good luck!!!
Tony
forgot: had to pull the alt. too
Old Feb 21, 2004 | 05:36 PM
Cmr0z28's Avatar
Tony
Hey Cman....thanks, BTW I'm MattZ28 on ws6zxr
Old Feb 21, 2004 | 06:22 PM
S.J.S.'s Avatar
My bad......Hey Fastbird and Slickblack.... how did you guys remove the manifolds?? From the top? Man, rebuilding the whole motor that gave me some of the most frustration. There was just no clearance to pull it out. I'm curious because if I go back and change to LT's later, I'd like to know.
thanks.
Old Feb 21, 2004 | 07:44 PM
fastbird96's Avatar
I pulled both manifolds from the bottom. Though the drivers side may come through the top.
Old Feb 21, 2004 | 09:21 PM
S.J.S.'s Avatar
And there you have it. Figures. Thanks
F'n1996Z28SS
Aug 23, 2023 11:19 PM
novaiiman
May 15, 2016 11:36 AM
Kyle@SLP
Jan 7, 2015 02:09 PM
Red97LT1
Aug 7, 2002 05:45 PM
