Guys with LT's inside please
Old Jan 27, 2005 | 01:11 PM
R8E1D's Avatar
I blew out my O2 sensors with no luck retapping it. So I decided to go ahead and get LT's and a new dual cat Y-pipe. Any suggestions? Im kinda on a budget so low prices would be great!
Old Jan 27, 2005 | 01:17 PM
fstenuf's Avatar
Re: Guys with LT's inside please
If you are on a budget i'd look for some MAC mid legth. easy to install and relatively inexpensive. unless you're all about long tubes then Hookers or Jet Hots would be a great choice. just my .02 worth
Old Jan 27, 2005 | 02:35 PM
Gripenfelter's Avatar
Why can't you weld on new bungs?
Old Jan 27, 2005 | 02:57 PM
R8E1D's Avatar
Yeah I could do that but I need to replace my Y-Pipe anyway so Im just going to do it all at once.
Old Jan 27, 2005 | 03:28 PM
Beyonce Knowles's Avatar
Pacesetter seems to be the way to go for people on a budget. I don't have anything to compare them to, but they installed real easy (both went in from the top, didn't have to jack up the engine) they have okay ground clearence, I can go straight over speed bumps, or sideways when other people are in the car, and they were the least expensive ones I found anywhere. Just do a search for pacesetter, I've never seen anything negative about them.
Old Jan 27, 2005 | 03:45 PM
Makaveli's Avatar
both went in from the top? looking at pictures those things look huge, did you have to take off a lot of stuff?
Old Jan 27, 2005 | 04:02 PM
Yep, and to top that off I did it by myself, nobody up there guiding it. The only extra thing I took off were the valve covers. It just took a lot of rocking and twisting. And the car wasn't even jacked up that high, it was on drive up ramps. If I had coated, I would have had to wrap them up real well, but didn't have any real problems.
Old Jan 27, 2005 | 04:25 PM
R8E1D's Avatar
Sweet I was hoping for not having a big hassle getting them in. I have access to a lift and friends that love to work on cars. But I have Eibach springs so I guess Im not going to have any ground clearance but thats okay. So are yours coated or not?
Magenta_Hearts
Mar 25, 2015 10:24 AM
cmsmith
Mar 14, 2015 03:48 PM
carl.froehlich
Mar 13, 2015 12:38 AM
squarehead
Nov 21, 2014 08:02 PM
Red97LT1
Aug 7, 2002 05:45 PM
