Guys with Jet Hot LT's. How'd you install the pass. header?
Old Feb 7, 2004 | 11:22 AM
snksknr94's Avatar
I've installed several different brands and of headers on different LT1's including FLP's on my own car. I decided to swap to the Jet Hots but I can't seem to get the passanger header in. It goes almost all the way in then where the 4 primaries come together it is to thick and hits on the tranny and the k memeber, and the heater case. going in from the top I get stuck at the same place on the k-member and the heater box, any suggestions?? I got the driver side in and all installed no problem, but the pass. side is kicking my ***.
Aaron
Old Feb 7, 2004 | 11:35 AM
speed_demon24's Avatar
Jack up the motor.
Old Feb 7, 2004 | 12:34 PM
ibanez6rg's Avatar
I jacked mine up ~32" or so. Removed the oil tube and starter, slipped right in.
Old Feb 7, 2004 | 12:50 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
tubular K-member and your done. Best investment you can make. Long tubes will slip right in no problem.
Like the others said, you'll have to jack the motor up.
Old Feb 7, 2004 | 01:34 PM
CamaroBoy96Z28's Avatar
Jacked up the pass. side about 3". Took 30 seconds to wiggle in.
Old Feb 9, 2004 | 02:06 PM
My95Z's Avatar
jacked up the motor, pulled the starter and the dipstick tube
Old Feb 9, 2004 | 02:32 PM
rpm4lalo's Avatar
I jacked up the motor and slightly grinded the k-member where it was tight to avoid scratching that jet hot coating.
Old Feb 9, 2004 | 02:40 PM
Brettinator's Avatar
about the same here too, but undid the pass side engine mount on mine and it finally slid in.
Old Feb 9, 2004 | 02:56 PM
Red96Lt1's Avatar
Pretty much the same as everyone, I had to take the valve cover off and jack up the motor. Went in from the top for me.
Old Feb 9, 2004 | 03:05 PM
Amped96's Avatar
I put the passenger side in from the top. Had to get it started going in with the motor down, then jack it up. Had to take the valve cover off on mine also though.
LT14LIFE
Feb 9, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Red97LT1
Aug 7, 2002 05:45 PM
