Guys with Dynatech long tubes, what plug wires do you use?
I just bought a '96 Z with Dynatech long tube headers. The previous owner had a couple wires burn on the header. I noticed that the plug wire boots on a couple the primary's are pretty much touching the header! Do you guys run over the valve cover plug wires, normal under the header routing, and to you use some sort of protective sleeve or shield on some of the boots??? Thanks for any advice!
Jeff
Jeff
Re: Guys with Dynatech long tubes, what plug wires do you use?
With long tubes, your best bet is taylor OTVC's IMO. I got mine from Thunder Racing and put them on last week. It was not to bad and the car runs great.
Jan 5, 2015 07:14 PM
Jul 4, 2005 05:00 PM
