Guys with AFR heads, recmd. on plugs
Old May 5, 2004 | 10:22 PM
TAChad's Avatar
Im experimenting around with some different plugs, but was wondering if anyone has found a plug (and Gap)that you have found work the best. I am going to try champion c59yc which is 3/4" reach, projected tip, copper plug with gasket, i believe. Im just trying to get the Gen 7 tuned on motor first...so i think these will work out until i spray the juice. I have 13:1 compression, 383 stroker, will be running running a Direct port 100 wet shot for now, running racing fuel, and tuning around 7400 RPM. Any suggestions, ideas or recommendations on type of plug and plug gap? Thanks
Chad
Highlander
Jan 12, 2020 02:13 PM
parkers Z28
Mar 11, 2016 08:14 PM
MadMav
Feb 6, 2015 11:02 PM
Highlander
Aug 9, 2002 02:30 AM
Red97LT1
Aug 7, 2002 05:45 PM
