guys with !ABS inside please
Old Apr 20, 2003 | 11:55 AM
funina91ss's Avatar
I am thinking of putting my 12bolt out of my camaro in the ta and its not setup for abs. so why have the xtra weight. my ? is did this cause you any problems with breaking a such. and how did you go about putting the lines to the master cly. to the brakes. TIA Sean
Old Apr 20, 2003 | 11:59 AM
IllusionalTA's Avatar
i dno't have abs /w my 9" and i have no problems.. i haven't even removed the abs stuff yet though ... I'm interested to know also.. though...
Old Apr 20, 2003 | 12:43 PM
Larnach's Avatar
A Currie 9" rear end housing made of aluminium is $550 brand new! Add a Reider Racing center section, weld on some custom brackets out of aluminum and you have a 75lb rear end
Old Apr 20, 2003 | 12:45 PM
funina91ss's Avatar
whats that have to do with !ABS
Old Apr 20, 2003 | 12:59 PM
Larnach's Avatar
Its related to it like this...
Guy wants a rear end, wants to save some weight, instead of dropping $2500+ on a nearly 200lb rear end, you can spend $750 less on the same thing, have it lighter, since your not using ABS anyway... just a thought.
Magenta_Hearts
Mar 25, 2015 10:24 AM
jj_burchiel
Mar 21, 2015 12:51 AM
carl.froehlich
Mar 13, 2015 12:38 AM
squarehead
Jan 15, 2015 07:02 PM
Red97LT1
Aug 7, 2002 05:45 PM
