Guideplate wear
Old Jan 1, 2006 | 05:56 PM
Jeff95TA's Avatar
Guideplate wear
While tearing the engine down I noticed that the guideplates have some wear from the pushrods. I'm running Pro Mag NSA with hardended pushrods and GM guideplates. Is some wear normal? A couple are pretty bad (one may be from when a rocker came loose).
I used a pushrod length checker when I installed everything and the rocker was in the correct place on the valve stem. The plates are flipped the correct way. Rolled the pushrods across glass, they don't seem bent. I even adjusted the guideplates as much as possible to center the pushrods in the grooves. On a few of the plates the wear is on the outer most edges of the intake and exhaust sides, so adjusting wouldn't help anyway.
Any thoughts?
Old Jan 1, 2006 | 06:33 PM
OBE1 95Z28's Avatar
Re: Guideplate wear
A lot of discussions on this topic, try the Search function. Here's one thread on the topic: http://web.camaross.com/forums/showt...ht=guideplates
Old Jan 1, 2006 | 07:29 PM
Jeff95TA's Avatar
Re: Guideplate wear
Did the search already, was hoping for something else. Not really sure where to go from here other than to recheck the pushrod length after rebuild & assembly.
Old Jan 1, 2006 | 08:52 PM
simple's Avatar
Re: Guideplate wear
i'm not sure if its normal but i had some wear on my GM guideplates also. not all of them either, just 2 or so
2QUIK6
Sep 17, 2016 02:31 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
WPHIG2
Aug 27, 2015 06:37 AM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
Jul 17, 2015 02:47 PM
