Guide Plates....
Old Apr 27, 2010 | 04:45 PM
19z28camaro02's Avatar
Guide Plates....
Heard a lot of people have been having alignment issues with guide plates due to the valve spacing on the heads. Anyone have any part numbers on ones that work? I have a set of Comp Cams guide plates in a box, can't find them and may need to re-order a set that works if these dont.
Old Apr 27, 2010 | 06:43 PM
RamAir95TA's Avatar
I used TFS 30400623-8 on my 383 with Trick Flow pushrods, and didn't have any alignment issues.
Old Apr 27, 2010 | 07:30 PM
tapout911's Avatar
I have a set of AFR guideplates that came on my heads. I pulled them off since I use shaft mounts. Id take $25 shipped for them. PM me if you want em.
Old Apr 27, 2010 | 10:21 PM
quiklt1's Avatar
i use and always have used 200-AGP isky adjustable guideplates for SBC put them were you need them and if you need to you can grind down the ends to give you extra clearence run them on my .605 lift hyd. roller never had a problem yet.
Old Apr 27, 2010 | 10:28 PM
Adjustable, Trickflows mentioned and GM guideplates (14011051) all work.
NewsBot
Sep 30, 2015 04:20 PM
karpetcm
Sep 15, 2015 11:07 AM
NewsBot
Sep 14, 2015 09:20 AM
Aaront810
Sep 11, 2015 11:24 AM
NewsBot
Aug 21, 2015 07:20 PM
