Guide Plates....
Guide Plates....
Heard a lot of people have been having alignment issues with guide plates due to the valve spacing on the heads. Anyone have any part numbers on ones that work? I have a set of Comp Cams guide plates in a box, can't find them and may need to re-order a set that works if these dont.
i use and always have used 200-AGP isky adjustable guideplates for SBC put them were you need them and if you need to you can grind down the ends to give you extra clearence run them on my .605 lift hyd. roller never had a problem yet.
NewsBot
Sep 30, 2015 04:20 PM
NewsBot
Sep 14, 2015 09:20 AM
NewsBot
Aug 21, 2015 07:20 PM
