guide plates
Old Apr 8, 2008 | 09:00 PM
11secgen's Avatar
guide plates
are you guys usin' flat guide plates? ilike the price of the trickflows. its for a 847 cam w/ 1.6 rockers.can i get a part number of the trick flows everyone is using?ive had to slightly notch guideplates before, so id rather do that than spend $50 on some isky's.but, if the isky's are the only thing that work, ill use those.
Old Apr 8, 2008 | 09:13 PM
dangalla's Avatar
honestly if i did it over again i would go with the iskys, they cost more and are a little harder to set up but i think it is worth it. i ended up having to end mill my trick flows a bit, but i dont think that is normal.
the part num for the trick flows is
Trick flow 30400623-8 guide plates.
Old Apr 9, 2008 | 05:08 PM
11secgen's Avatar
ok thanks alot. my local speed shop has trickflows, but id have to order the isky's. im not sure if i can wait any longer!
anyone else use the trickflows w/ 847 cam and 1.6 rr?
Old Apr 9, 2008 | 05:16 PM
11secgen's Avatar
ok, i just dug up an old post ,that answered my question.a guy w/ an 847,1.6rr ans comp 5/16 pushrods typed that his was rubbing pretty bad.i guess isky's are the only way to go w/ my combo.
Ericksd
Jan 20, 2016 06:07 PM
NewsBot
Sep 30, 2015 04:20 PM
95blkss
Sep 22, 2015 03:18 PM
NewsBot
Sep 14, 2015 09:20 AM
Aaront810
Sep 11, 2015 11:24 AM
