guide plates
Old Sep 22, 2007 | 07:42 PM
93camarochrisz28's Avatar
guide plates
i called my local speed shop today and asked about getting guide plates for my lt1 heads and he said that i have to get machien work on them to make them fit do i or can they just bolt right up
Old Sep 22, 2007 | 08:20 PM
speed_demon24's Avatar
They just bolt right up. I have some trickflow guideplates if you want them. I'm not sure where in FL you are since it would probably cost as much to ship them as they are new.
Old Sep 22, 2007 | 08:55 PM
seawolf06's Avatar
ISKY or GMPP guideplates are the only ones that will work for sure. I don't remember about the trickflow's but if speed_demon says they do, then they probably do. He knows.
Old Sep 23, 2007 | 11:31 AM
a walker's Avatar
Your machinist probably assumed you were talking about the Gen I LT-1 that had pressed in studs. Heads that have pressed-in studs need to have the rocker stud bosses machined flat for bolt-in rocker studs.
They will work fine.
Old Sep 23, 2007 | 11:40 AM
Originally Posted by a walker
Your machinist probably assumed you were talking about the Gen I LT-1 that had pressed in studs. Heads that have pressed-in studs need to have the rocker bosses machined flat for bolt-in rockers.
yeah that sounds just like what he said thanks alot
Ericksd
Jan 20, 2016 06:07 PM
NewsBot
Sep 30, 2015 04:20 PM
95blkss
Sep 22, 2015 03:18 PM
NewsBot
Sep 14, 2015 09:20 AM
Aaront810
Sep 11, 2015 11:24 AM
