guide for changin injectors?
Old Sep 16, 2004 | 02:46 PM
Seal's Avatar
anywhere?
thx
Old Sep 16, 2004 | 03:21 PM
Valkyn71's Avatar
Re: guide for changin injectors?
Disconnect fuel line, loosen 4 bolts, pull up fuel rail.
Remove the little clips, throw them in the trash.
Pull out old injector, put a little Lube on the new O-ring if you want, slide them up in.
bolt it back on and reconnect the fuel lines.
Dont start it without tuning to compensate for the new injectors.
Old Sep 16, 2004 | 03:23 PM
disco192's Avatar
There isnt a guide, because its so simple. Just take off the bolts holding down the fuel rail (9mm i believe) and then pull it up. Keep a rag on hand to clean up spilled gas. Then just slip the new ones in. Should take about 15 mins tops. If the o-rings dont come out, then get a screwdriver and carefully pull them out.
Voilla... done.
Old Sep 16, 2004 | 03:30 PM
Seal's Avatar
where do i disconnect the fuel rail from? (like wherever it gets fuel from) or do i even need to do that?
do i fully need to take out the fuel rail, or just sliding it out a bit will do the trick?
Old Sep 16, 2004 | 03:41 PM
disco192's Avatar
You dont need to remove the fuel rail. Just lift it up. Dont disconnect the lines. Thats more work than is necessary.
Old Sep 16, 2004 | 03:45 PM
turbo_Z's Avatar
You dont HAVE to disconnect the lines btw. Just be careful b/c fuel will spill out when you pop that first injector out. Also its very important to lube those o-rings or you might end up ripping one and not finding out till your car nearly bursts into flames... trust me its not a fun experience.
Old Sep 17, 2004 | 10:44 PM
VeryBad's Avatar
Got one on my site
http://www.witchhunter.com/lt1injectorreplace2.htm
GordonWitchHunter Performance
Old Sep 18, 2004 | 02:00 PM
Loadre's Avatar
It's much easier on you if you disconnect the lines and pull the rail off. Make sure to also take the vacuum hose of the FPR on the back. Your back will thank you.
Old Sep 18, 2004 | 03:13 PM
PoorMan's Avatar
Please relieve the pressure first. Unscrew the gas cap then push in the schrater (sp?) valve with a screwdriver or whatever. Have a rag ready to wipe up the fuel. You will be in for "gas in ya face" if you pull a injector off with any pressure in the line.
Old Sep 18, 2004 | 07:57 PM
Z95m6's Avatar
You can do it without removing the fuel lines from the Rail. I just installed some Comp R's in my motor and i didn't take the fuel rail off. I just tucked it back behind the motor. I would of pulled the fuel lines but a friend (turbo_z) had my tool, Azzhole. If you don't have access to a fuel line remover just do it with them hooked up. By the way the bolts are 8mm. I have to take them out everytime i remove my Ram Air, which is almost everytime i work on the damn car.
13qtr
Oct 28, 2016 08:11 PM
Nutty's96
Dec 21, 2015 06:25 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
4586
Aug 22, 2015 01:09 AM
