Gtech real simple question
Old Feb 17, 2003 | 01:23 AM
ryker77's Avatar
I'm about to install some headers, plugs, wires, coil, remove AIR pump and EGR system. I would like to see how much HP is gained.
With the G-tech do you have to start off at zero mph the WOT to get the HP reading? Or can I be in third gear at 50mph? I ask because my car would have zero HP because it would just spin if I started in 1st gear WOT.
Old Feb 17, 2003 | 04:24 AM
Laymaster's Avatar
It's a standstill measurement. I remember doing it, standing still, set it up, it said "ready" then I hammered it in first gear until the redline, let off the gas. When you let off the gas, it goes to "calculating" and it gives you a readout. It told me 225HP when my car was stock.
Old Feb 17, 2003 | 07:47 AM
magius231's Avatar
you can measure it at any speed....just remember that due to wind resistance and lower gearing your going to get a lower reading at higher speeds. I measured mine from 60-75 or so and got a max of like 100HP.
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 08:12 AM
Hurin
Dec 13, 2014 07:38 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
