groun wire?
Old Sep 23, 2007 | 11:31 PM
383camaro's Avatar
ground wire?
Does anybody know what this ground wires is for besides the pcm. Like what sensor is it for?
Old Sep 23, 2007 | 11:38 PM
mdenz3's Avatar
That is to insure that the PCM and the engine have are grounded to each other so that sensors like the coolant temp which ground through the block (water pump) will read acurately. Without it if the pcm has .7 Ohms on its gound and the engine has .1 Ohms on its ground the sensors reading would all be affected by .6 Ohms.
Old Sep 24, 2007 | 06:45 AM
The ground is for:
PCM
oil level sensor
MAF
theft deterrent module
transmission range switch (auto)
fuel pump relay
instrument cluster
performance switch (if equipped)
traction control (if equipped)
ground to DLC
Old Feb 6, 2008 | 07:27 PM
asia517's Avatar
Originally Posted by shoebox
The ground is for:
PCM
oil level sensor
MAF
fuel pump relay
instrument cluster
ground to DLC
If this wire isn't getting a good ground would that stop the car from starting?
Old Feb 6, 2008 | 11:18 PM
Some people have accidentally had it disconnected and it still ran, but of course, it should be connected.
Old Feb 7, 2008 | 08:14 AM
kgkern01's Avatar
I was just about to post asking about this same wire. I noticed mine was cut somehow while putting in a new trans and fixing a burned O2 wire on the same harness. Guess I need to ground this thing.
Old Feb 7, 2008 | 08:25 AM
THE_RUCKUS's Avatar
i would imagine they would share the common ground to provide accurate readings and to minimize the chances of any sort of voltage drop which would give false readings and throw off the computer
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
