Grinding down dowel pin.
Old Apr 30, 2003 | 09:58 PM
  #16
94foormula's Avatar
Originally posted by muraoka
i to had to grind while the cam was installed. i used a piece of old inner tube cut a small hole then turned a tube to fit the i.d. of the opti seal. pressed the tube in and used an angle grinder with a 3/4 sanding disc.if your not in a hurry send me your address and i'll send you the tube.
matt
Thanks a ton but I need to do this within a day or two. I will steal your idea though.
How did you know how much to take off, any special method?
Old Apr 30, 2003 | 10:02 PM
  #17
94foormula's Avatar
Originally posted by Smokn '94 Z
Ahhh. Me stupid... I can't comprehend what I read. Sorry. I definately wouldn't tear the cam out either....
Also I wouldn't tap it in with a hammer either...... with the cam in the car...
No problem, thanks for all your help. J/K
Old Apr 30, 2003 | 11:34 PM
  #18
muraoka's Avatar
just thought i'd offer. i used a caliper measured it first and just kept checking.i'm a machinist by trade so i got pretty good at judging thousands.best of luck to you i'm sure you'll get it done.by the way i broke 2 opti's before i figured it out.
matt
Old Apr 30, 2003 | 11:59 PM
  #19
Mr_Superman's Avatar
Just wondering but on a 94 car with the small dowel would it even matter if it was even out?.....Like couldnt you just grind it even with the cam? As in the longer dowel frrom the lt4 cam...
Formula Steve
Sep 19, 2023 08:31 AM
Bxlt1
Sep 29, 2015 03:18 PM
4586
Sep 27, 2015 01:55 PM
Greg88
Aug 24, 2015 07:59 AM
