Grind or Cut Cam Dowel Pin?
Old Mar 24, 2006 | 01:28 PM
  #16
Cmr0z28's Avatar
Re: Grind or Cut Cam Dowel Pin?
Originally Posted by F6
I cut my pin and pluged the hole this way.
http://images.fotopic.net/y9iqc6.jpg
This is why you check the length BEFORE you install the cam.
Old Mar 24, 2006 | 01:33 PM
  #17
Jeff95TA's Avatar
Originally Posted by markpaul
I think Comp should relize they are being a pain in the *** with this because most of us don't realize that the pin is too long until the FUGING CAM IS IN THE CAR WITH THE HEADS ON!
But aren't they selling the cams as a general LT1 cam, not a year specific cam?
Old Mar 24, 2006 | 01:51 PM
  #18
94_6speedZ's Avatar
Yea, there is only one version of an LT1 cam, that I've seen anyway.
Old Mar 24, 2006 | 02:59 PM
  #19
markpaul's Avatar
Its all great in theory to check this stuff before but guess what....most of us won't notice a small difference like that or even think to check it. You expect it to fit since you ordered it for the specific car/engine...
Old Mar 25, 2006 | 12:14 AM
  #20
nb 96 z's Avatar
Originally Posted by 94_6speedZ
I live off Warren between Sheldon and Canton Center. How come the cam is sitting in your room? Are you just waiting to put it in?
Pretty close to me. I live off saltz between sheldon and canton center. Yeah I'm gonna put the cam in one weekend when the weather gets a little warmer so probably sometime in april.
Old Mar 25, 2006 | 09:56 AM
  #21
kirschman's Avatar
I had to cut my first cam's pin (CC306). Just butt it up against your factory cam,t/c end to t/c end and mark the difference. I used a dremel with a diamond cut off wheel, took like 30 secs. or sumin like that. Not for sure what the deal with length's being off from year to year but my LE2 cam was the correct length from CC
Old Mar 25, 2006 | 10:08 PM
  #22
Comp Cams recommends checking the length of the dowel pin and you should, no matter if it is supposed to be the right length or not. That's just part of doing a cam install correctly.
Old Mar 26, 2006 | 04:57 PM
  #23
mattbailey's Avatar
Originally Posted by Hotwire
don't press the pin back into the cam, i bought a cc502 that had the pin pressed in and it was dayum near impossible to remove it. That's a ****ty way of doing things. cut it.
Don't give bad advise, any decent machine shop has the proper tools to remove dowels.
Old Mar 26, 2006 | 05:45 PM
  #24
Hotwire's Avatar
sorry mommy, a hydraulic press and dent puller wouldn't touch it. it was not heated to keep from warping or messing w/ the hardness of the metal. it was eventually pushed back into the fuel pump eccentric, cut, pushed more till it hit again, etc.
I will keep my thumb in my mouth and off the keyboard from now on.
Old Mar 26, 2006 | 05:55 PM
  #25
mattbailey's Avatar
Best thing I've heard come out of your mouth.
Old Mar 28, 2006 | 08:43 AM
  #26
94_6speedZ's Avatar
Thank you for all your advise I went ahead and used a grinder to shave it down. I chamfered the edges with a file to look something like the stock cam.
I can't wait to get this cam in and get it back together.
Thanks again,
-Greg
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Cam's maro
Jan 30, 2015 09:21 PM
