Great!! p300 on 96 camaro lt1
Old Aug 18, 2010 | 12:38 PM
ClassyKilla's Avatar
After running scan at local chevy service shop my camaro is getting p300. we norrowed it down to a misfire on cylinder 1. been puttering for about 3 months. The service shop wants a little over $2000 to correct the issue. they stated that the water pump is leaking and seems to be the culprit. I have had the opti repaired about 5 months ago with sometype of bonding metal stuff. Which worked for a short time. Well I can't afford their heavy price. After reading some posts here on this site I noticed that some experincing the same issue. I'm looking for some advice on the order that i should start troubleshooting. My car has been maintained from day one and has 91,??? milles on the OD. Any help would be appreciated for a newly married couple loking to save some money.
Old Aug 18, 2010 | 01:06 PM
RamAir95TA's Avatar
What kind of plugs and wires are you running? With the engine running look under the hood in the dark and look for any obvious arcing around cylinder 1, assuming that is where the problem is. Did you use a scan tool with enhanced GM parameters?
Old Aug 18, 2010 | 01:30 PM
GRIDERMAN87's Avatar
if the water pump is leaking it needs to be replaced, but could be a do it yourself job, the opti can be done also its a little more involved though. did you say you put metal bond somewhere in the opti? or the water pump?
Old Aug 18, 2010 | 02:00 PM
I will look at it tonight. I had the scan ran at the chevy dealer. so i would "assume" they would have.
Old Aug 18, 2010 | 02:10 PM
The mechanic put it on the opti because they stated it had like some amazing arcing. That seemed to have corrected the issue for a short time. At that time they stated all the plugs and wires were fine. Should I get a gm water pump or is there another that I should consider? I guess that i am going to need to replace the opti aswell.
Old Aug 18, 2010 | 02:31 PM
Mswezey's Avatar
From: Wichita Falls, Texas - College. DF-Dub, when not in college
i got a waterpump from autozone for $60.
Old Aug 18, 2010 | 03:07 PM
The pump depends on you really, if you wanna save money i would buy an autozone pump or something similar, GM pump would probably be of a little better quaility, but is gonna prolly be double the price. If the pump is leaking it could be messing the opti up, my brothers car did almost the same thing yours is doing and changing the pump fixed his problem....but your opti may be done for so it would probably br good to change it out, if thats wat is causing your problem
oldschool
Feb 9, 2016 09:21 PM
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
hotrodyou1
Dec 20, 2014 10:05 PM
mspennyhughes
Nov 28, 2014 03:22 PM
