granitelli is it pointless?
Old Jan 11, 2006 | 11:20 AM
Critter's Avatar
i'm getting rid of the stock maf that i probably destroyed while porting it and replacing with a granitelli that i got for 90 shipped.
also madtunz (i think is the name) is this pointless with my current set up and how much of a gain would i expect from the granitelli, or the madtunz
Old Jan 11, 2006 | 11:25 AM
96flame's Avatar
Re: granitelli is it pointless?
Make sure you tell Ion that you have the grantnelli MAF when you get the tune. The stock MAF would be fine but since you needed one then use it. Just make sure the tune is proper for it.
Old Jan 11, 2006 | 11:30 AM
camarokid24's Avatar
If you messed up your old mas aif flow sensor then yeah its worth it. MadZ28 PCM tune can give you more hp, I think 10 to 17hp over stock. So yes to both If you were replacing a good MAF then no not worth it.
Old Jan 11, 2006 | 11:53 AM
Critter's Avatar
not sure if i messed it up but i have a rough idle and i think it's leaning out on the top end. sputters somtimes.
Old Jan 11, 2006 | 04:42 PM
bdc95ta's Avatar
I'm going to try the granitelli w/ my heads & cam setup b/c I calculated the stocker to be a restiction.
-b
Old Jan 11, 2006 | 04:48 PM
blkchevyz's Avatar
-b
how did you do that?
Old Jan 11, 2006 | 05:46 PM
madwolf's Avatar
I have tested cars on the dyno (400+ RWHP) with big heads and cams and the stocker was not a restriction. Granatelli is a mass airflow sensor that was intended to trick the PCM into thinking the car is getting less air so that it dumps less fuel, therefore leaning the WOT curve and gaining a few HP that way, not because it's less of a restriction. That sensor will only complicate things on modded cars.
Old Jan 11, 2006 | 05:51 PM
bdc95ta's Avatar
You calculate how much cfm's your engine needs. Then based off the area of the MAF you figure how many cfm's can pass through. Just like you would a throttle body (48mm,52mm,58mm or mono). You just subtract the metal peice from your calculations for the stocker. There's also data online where people have flow benched them.
For a stock or bolt on car the stock maf is fine. I can't remember the exact # but I believe it was around 750-850cfms for the stocker. I'll check when I get home tonight.
-brandon
Old Jan 11, 2006 | 08:19 PM
96capricemgr's Avatar
Originally Posted by Taintedz28
I bought it brand spanking new and I could feel a difference in it. also the granatelli flows more air than the stock MAF
Read what madwolf posted you might actually learn something.
Old Jan 11, 2006 | 08:55 PM
Critter's Avatar
hey tainted... i hate to break it to you... but your car does not have 330 hp. i looked at your cardomain site... how did you get 330?
Old Jan 11, 2006 | 10:48 PM
truedualws6's Avatar
With a dyno tune which should compensate for the calibration of the MAF
the GMS MAF was worth 1rwhp/3rwtq for me. Not really enough to even
consider, or probably valid as a data point. I got it cheap and like it, but
I'm also the minority on this topic. I'm in lots of rush hour traffic and it
probably heat soaks less.
Old Jan 12, 2006 | 09:21 PM
Critter's Avatar
that sucks
Old Jan 13, 2006 | 07:14 AM
Go back and read madwolfs post AGAIN you may have felt gains but NOT from more airflow.
A 5 gallon bucket with the bottom cut off would flow more air too, doesn't mean it will make more power.
Old Jan 13, 2006 | 08:00 AM
-brandon
A CFM flow number is only part of the calculation. What did you calculate the pressure loss to be for the various MAF's you evaluated? If the stocker isn't causing a lot of pressure loss, opening it up isn't going to make much of an improvement.
Old Jan 13, 2006 | 09:13 PM
bdc95ta's Avatar
I just calculated the flow # in cfm, I don't know how to calculate for pressure losses? I guess you could test it w/ equipment right? If you had something hooked up befor and after the maf senser? Can you calculate it analytically?
-b
