gotta budget of....
Old Nov 25, 2009 | 04:42 PM
ibringdarukus's Avatar
gotta budget of....
$2,000.. Not much but i want to put it all into my car.. any suggestions?
94 Z28 Camaro A4 130k.. Never been Rebuilt (motor or tranny)
stock motor .. only got a moroso cai ..
thanks!
Old Nov 25, 2009 | 04:51 PM
Black 97 SS's Avatar
longtube headers, y pipe, catback exaust, depending on your stock gears (2:73's or3:23's) put 3:73's in. That will make a noticable differece in the car
Old Nov 25, 2009 | 04:55 PM
what kind of muffler would u suggest? i have a flowmaster right now .. sounds real good but i dont know if its the best performance wise
and when it comes to the headers and catback do name brands mean anything?
Old Nov 25, 2009 | 08:06 PM
green96ta's Avatar
easy
with long tubes and an ory you should go with a magnaflow catback. hands down. amazing sound esp. for the price....
Old Nov 25, 2009 | 08:15 PM
reamo04's Avatar
pacesetter longtubes and ORY - get the coated ones, and then a catback of your choice. The best flowing ones that are good prices are magnaflow and hooker. The magnaflow is stainless though, so its pretty nice.
Also look into a nice torque converter, look at a yank ss3600.
Those two things should put you right around a fifteen hundred with a very noticable improvement.
Than you can add 3.73 gears for probably 500 installed, which should put you right at your 2,000 budget.
Or, you could drop the whole 2 grand,a nd buy a a 9" with 3.73s or 3.90s and never have to buy another rear end again.
What are your goals for the car? is it a daily driver?
Old Nov 27, 2009 | 12:08 AM
I run Pacesetter coated longtubes, off-road ypipe and two on the left exaust, sounds nice, my buddy has the same headers and ypipe with a hooker catback, sounds really nice also. Next time I do headers on the car im gonna go stainless, but for a good budget header made in the USA which offers a great fit, I say pacesetters are the way to go. As mentioned earlier a stall would make a noticeable improvment as well. On a stock car a nice full exaust setup would be my first choice
Old Nov 27, 2009 | 12:28 AM
NightShadeZ28's Avatar
You can save a good amount of money by dropping the cat back exhaust and running true duals. I spent around $700 for my whole exhaust set-up and that is installed. Pacesetter ceramic lt headers and the parts from the site below, except dynomax bullet mufflers instead of flowmasters. A normal cat back system is at least a $1,000 or more. And the power gains are much better than a cat back system. The down side is they are louder and not emissions legal. Here is a site to help you out.
http://www.lt1engine.com/tech/how-to...duals-exhaust/
Now with the rest of the money I would definently look into some 3.73 gears. Someone mentioned $500 installed and they are right on the money with that. So with the other $800 a mail order tune and a yank ss3600 stall like mentioned above should make a nice improvement..
Old Nov 28, 2009 | 08:49 PM
thx!!
Old Nov 29, 2009 | 07:17 AM
bw_hunter's Avatar
Name brand cat back systems can be had for $500...Hooker Aerochamber. You can spend a great deal more but don't believe that you HAVE to spend $1000 on an exhaust system.
The way to generate power in an engine is to make it breathe. You started well with the CAI...headers, a y-pipe and a cat back are the next things to invest in. You'll want coated headers to keep underhood temps down.
You can do a lot to these engines..how much is really up to your wallet.
If you've done the free mods...TB coolant bypass, etc. Then you can go to the engine internals or work on other things like the rear and suspension. 3.73 gears really wake up the automatic equipped cars. Aftermarket rear lower control arms can help you put all the power you have to the ground, maximizing the bucks you put into it.
Some mods require supporting mods. The higher stall speed torque convertor mentioned above requires the use of an aftermarket transmission cooler.
So after you add things be sure to get a tune. You can get some good gains on a basically stock engine with a mail order tune. Oh, one last thought...if you're going to get a tune, add a 160F thermostat and have the tuner do his thing there as well. He'll add some timing advance and get you some power..
If you want an idea of what mods can get you how much power, take a look at www.ws6.com/ The guy has dyno'ed his mods before and after indicating what you can expect both on average and at peak. Sure it's one guy on one dyno and won't be exactly what you'll get but it'll give you something....
Old Nov 30, 2009 | 11:53 AM
Yes you can get a cat back system for $500 or so but then add the y pipe and LT headers and to have it welded and mounted up a $1000 or over. A full 2.5" true dual system with LT headers welded and mounted $700 or less. And like I said better power gains and the sound that makes people jealous.
Old Nov 30, 2009 | 11:55 AM
bw_hunter's Avatar
Ahh, I see what you mean. But I think that $700 is a little light...coated LT's cost more than $500 any more....
Old Nov 30, 2009 | 01:57 PM
reamo04's Avatar
pacesetters are right about 400 for the coated ones. Xpipe is 100, bullets are around 40/piece.
There ya go, long tubes and true duals for about 700 if you can install it all yourself
Old Nov 30, 2009 | 02:03 PM
bw_hunter's Avatar
Thanks much...take care,
Old Dec 2, 2009 | 12:36 PM
I had mine welded and mounted for $700 with ceramic pacesetter LT's, X-pipe and Bullets.
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
NewsBot
Aug 21, 2015 07:20 PM
gonzo275rltw
Jul 11, 2015 04:19 AM
pimpen1024
Jul 8, 2015 09:08 PM
