Got some new times with 3.73's
Old Oct 13, 2005 | 10:44 PM
Alvin@pcmforless.com's Avatar
I have a 93 Formula, 6 speed with a vortech T-Trim stock pulleys and a 9:1 355. I had a problem launching my car with 3.23's. It has a 1994+ six speed which is meant for at least 3.42's. It would either bog or spin... no in between.. best before tonight was a 7.96 @ 93mph
Kelly put a set of 3.73's and I had a chance to try them out tonight.
1.73 60'
7.57 1/8th ET
95.39 MPH
When have you ever heard of a small gear change like that help take off 1/2 a second in the 1/8th? This thing kicks some *** now!!
The car's only suspension mod is a set of LCA brackets. Its on a spec stage 3, richmond 3.73's and BFG 17' drag radials. It drives like a factory car with a small comp cam 210/220 @ .050 .510/510 lift cam. Its still 355 CID 9:1 compression and i'm using the lowest boost pulley I have for my vortech T-Trim Aftercooled. The pulley is actually so big its cutting into my upper radiator hose!!!
Its also full weight.. nothing at all has been removed. Still has all its seats, a/c cruize, etc.
Oh its also still on the stock 10 bolt!
man I"m really happy with this car right now!!!
Old Oct 13, 2005 | 10:50 PM
Makaveli's Avatar
Re: Got some new times with 3.73's
thats an amazing time drop, congrats!
i fear for your 10 bolt though
Old Oct 13, 2005 | 11:00 PM
SS RRR's Avatar
Not surprising at all. Sounds like the car is spending more time in its power peak where it should be.
Old Oct 13, 2005 | 11:12 PM
2000GTP's Avatar
Very impressive gains.
Old Oct 13, 2005 | 11:28 PM
FastZinTennessee's Avatar
Very nice times!! Always good to be pleasantly surprised by a modification.
Old Oct 13, 2005 | 11:38 PM
1racerdude's Avatar
The rule of thumb is "keep throwing gear at it till it slows down and back up one"
Old Oct 14, 2005 | 06:14 AM
Fastbird93's Avatar
Nice times! I knew those gears would help ya! BTW, you know where you need to post this......
Old Oct 14, 2005 | 09:02 AM
T/A lt1's Avatar
Nice gain from only the gears. I would like to see what it would do with 3.42's. My old combo similar to yours, daily driver full weight T/A, with a Hotcam kit, stock 3.23's, 2800vig and a 150shot ran 1.70 60' on drag radials but 7.40@98 1/8th and 11.40@122mph with stock heads. I am glad n2o isn't so finicky about gear it likes a high gear. Later Clint
Old Oct 14, 2005 | 09:20 AM
OutsiderIROC-Z's Avatar
Yup
Old Oct 14, 2005 | 12:19 PM
cas0484's Avatar
Nice gains, I have a set of 3.73's waiting to go in as well. I hope to see some decent gains from them, although I doubt I'll drop .5 in the 1/8.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
