Got programming, but car still idles high?
Old Apr 20, 2004 | 08:35 PM
97silverTA's Avatar
I just put a hotcam in my 97 lt1. I got the computer programed to idle at 850, but it idles at 1100. It idled this high before the cam also. I really need help because I want it to lope, but it doesn't lope good at 1100. Thanks for your help.
Old Apr 20, 2004 | 08:38 PM
Robs97Z28's Avatar
thre is an Idle set screw on the tb, but I not sure the would truely fix your problem.
Old Apr 20, 2004 | 08:53 PM
97silverTA's Avatar
Where is the screw located? is it easy to adjust or do you actually have to grind it down?
Old Apr 20, 2004 | 09:04 PM
Robs97Z28's Avatar
you shoyld have a plastic cover on the drivers side. It coers the linkage, remove it. I think you have to remove the tb to make the adjustment. you should see the set screw it is nidden by the gasket. that is what I can remember when I removed mine to clean it.
Old Apr 20, 2004 | 09:20 PM
scoobysnax83's Avatar
just to let you know, my car idles at 800 and the hotcam doesn't lope much at all
Old Apr 20, 2004 | 10:09 PM
You really should not need to be messing with the idle screw unless it has been messed with before. It would be wise to put a scanner on it and see what the PCM is commanding for idle and what the IAC counts are.
Old Apr 20, 2004 | 10:11 PM
Tony Danza's Avatar
is it the stock TB?
Old Apr 20, 2004 | 10:59 PM
97silverTA's Avatar
It is the stock TB.
Old Apr 20, 2004 | 11:01 PM
Kryckter's Avatar
I also believe that if you change the idle screw the PCM will compensate for it. I really dont know, You may want to take out your IAC valve on the bottom of the TB and clean it all up, You may have a slight vacumm leak somewhere near the TB that is making it idle a little high. It would be good to do some logging on it to see what the sensors are reading if you can. Otherwise just try cleaning the IAC valve and see where that takes you.
Old Apr 27, 2004 | 04:34 PM
blown383's Avatar
Im having the exact same problems....let me know if you find out what it is.
-B
Old Apr 27, 2004 | 05:03 PM
BUBBA's Avatar
Are you sure that it is actully idling at 1100 or is that just what your tach says?
The tachs, as you probably know, show 200-300 high.JMHO
Old Apr 27, 2004 | 07:01 PM
blown383's Avatar
Thats what the stock tach says....my cam is the CC xtreme 236/242 and its ground on a 110lsa...its suppose to lope like a ****!!!!!
-B
Old Apr 27, 2004 | 08:07 PM
Zepher's Avatar
Maybe there isn't enough vacuum and the IAC motor isn't able to compensate, or it's stuck. I'd clean the IAC and passages.
Old Apr 27, 2004 | 09:57 PM
blown383's Avatar
I spent an hour cleaning the IAC and TB yesterday now when I start the car it revs up to 2,000rpm then takes a few seconds to settle back down to 1,200rpms. I think the IAC is messed up and the replacement cost is $49.00 from Autozone for a Wells IAC, the AC Delco unit is about $52.00 from GM Part Direct.
Anyone know how to diagnose if teh IAC is functioning properly?
I think I may have bumped the pintle and threw it off calibration.
-B
Britbilly
Jan 7, 2015 08:49 PM
Dec 23, 2014 07:52 AM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
Jul 4, 2005 05:00 PM
