got the p0410 secondary air injection system
Old Sep 17, 2012 | 03:35 PM
javi805's Avatar
the check engine recently came on and i got code p0410 . i am wanting to change the air pump but before i do should i check the pump to see if the pump still works i mean can it also be an electrical problem right??
Old Sep 17, 2012 | 03:52 PM
RamAir95TA's Avatar
Re: got the p0410 secondary air injection system
Check the fuse first. If it keeps blowing your AIR pump is probably on its way out (covered by a factory TSB IIRC).
Old Sep 17, 2012 | 04:23 PM
javi805's Avatar
Ok got it,i will def check that out,thanks
Old Sep 18, 2012 | 01:48 PM
P0410 is specifically for lack of air flow when the PCM cycles the AIR pump and the O2 sensors do not show a lean condition. P0412 would set for a blown fuse. You could have a melted hose or a stuck check valve. Or could be a faulty pump.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Sauced
Mar 29, 2015 10:53 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
Jul 4, 2005 05:00 PM
