Got my PP93 T/A Dyno Tuned......Something seems off....
Old May 24, 2004 | 11:52 AM
  #16
magius231's Avatar
and FWIW, what I have been reading notes that LT headers will typically pull better down low, whereas shorties are high RPM headers. The main reason people note such a difference with LT's is they just got back a chunk of what they lost (or didn't gain) on the bottom by going with a big cam/higher RPM setup or shorty headers. Since noone drives there car around at 4k RPM, its more noticeable.
Old May 24, 2004 | 11:58 AM
  #17
aintno6's Avatar
2 Things I Noticed
1. Because you have a stall converter, that takes some of the hp #'s in your dyno.
2. You at least need a cutout. You need somthing to let that exhaust flow with minimum restriction. And most mufflers are going to do so, especially a flowmaster, due to the chambers. So get a cutout, dont waste the money on a catback, because what if it doesnt help out much. Thats $300 down the drain.
Or....... dissconnect your catback from your y-pipe, and run your car that way.
Old May 24, 2004 | 12:21 PM
  #18
Shon Herron's Avatar
I dont see anything wrong. I was able to tune to a rich 340 with the set up in the sig. 105 is about right, i am in the 111 range on a good day after some more on track tuning (leaning it out).
And the debate of the LTs, someone donate me some shorties and y and i will pull with the LTs and the shorties and see the difference. My money is that not much difference on track or dyno.
Old May 24, 2004 | 12:29 PM
  #19
bunker's Avatar
I bet those heads aren't what you think they are thats all.
On the side note, 1 3/4 headers will make more power then 1 5/8, shorty headers will pull better up top then long tubes because the longer primaries build tq not HP, dont' want to go into it again, read my previous posts.
Old May 24, 2004 | 04:57 PM
  #20
Fastbird93's Avatar
Originally posted by aintno6
2 Things I Noticed
I have no stall convertor, as I don't have an A4. It was swapped to a six speed before coming into my possession.
I will not be going the cutout route. I really think that the flowmaster piping in the cat-back has a lot of restriction in it, and the 52MM TB could only help. The heads are from a very reputable person according to the previous owner, and should be fine. From what I've seen, a ported head/hotcam setup usually sits between 350-370 dependent on setup. I'm not screaming for a ton more power, just trying to figure if I can get it above the 355-360 mark. The heads are working as the TQ shows that in itself.
fift5
11
Oct 1, 2015 10:31 AM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
