got my new exhaust setup i wanted in...
Old Apr 30, 2006 | 04:22 PM
gbu27's Avatar
well i got in a whole new exhaust i ordered, pacesetter LTs,offroad y pipe, gmmg chambered exhaust and 2 pypes mini cats. i got the cats so i can pass inspection, but i think i might have a problem. was planning on getting a shop to cut the y pipe and weld in the cats, but the y pipe is 3" and the cats have 2 1/2" opening ( i think thats what it is) , either way, its alot smaller, is this gonna be a problem or can the shop get some kind of adapters. the cat itself is 3",so is the smaller opening and exit gonna be restrictive being smaller? dunno if what i am saying is confusing, but that was alot of money and i want to make sure it all works together well
Old Apr 30, 2006 | 04:28 PM
Cerwin Vega Fan's Avatar
Re: got my new exhaust setup i wanted in...
Run 3 - 21/2 adapters. And yes their may be a small restriction in flow but nothing to write home about.
Old Apr 30, 2006 | 05:53 PM
MeanGreen97Z's Avatar
If it is a 3" cat then it will have a 3" opening. Shouldn't be 2.5" but if it is it wont make a huge difference. Have them flanged so you can take them out and put them back in as desired. That exhaust is going to sound sweet!
Old Apr 30, 2006 | 09:34 PM
gbu27's Avatar
think ill try and post a pic of it, im beginningto think i got sent the wrong item, im gonna have to double check
Old May 1, 2006 | 11:38 AM
gbu27's Avatar
found out i got sent the wrong item, i ordered 2 cats, one is the right size, one isnt.. sending it back in
Old May 1, 2006 | 12:45 PM
MAJESTIC's Avatar
who did you buy your cats from??
and do cats make your car quieter?????
Old May 1, 2006 | 01:02 PM
sandman63's Avatar
Man that sounds like one sweet system good luck with that.
Old May 1, 2006 | 02:20 PM
gbu27's Avatar
cats came from www.rpmoutlet.com
Old May 1, 2006 | 03:59 PM
2000GTP's Avatar
You will have a nice sounding and looking exhaust setup once you get the cat issue sorted out.
Old May 1, 2006 | 08:43 PM
gbu27's Avatar
yea they already responded, should get the echange done in about a week i think.And one question, do i need O2 extensions for the front O2s, or would they just be the rears?
Old May 1, 2006 | 08:50 PM
2000GTP's Avatar
You will need 02 harness extensions for the front two 02 sensors. Since you are running the Pacesetter off-road y-pipe, it does not have 02 bungs for the rear 02 sensors for the simple fact that the y-pipe was designed without cats. You can do away with the rear 02 sensors altogether by using either 02 simulators which can be purchased through Thunder Racing or some of the other online retailers for about 90 bucks for the pair, or you can have the rear 02s tuned out of your PCM.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
