got my heads form loyd today heres the flow #s
Old Aug 27, 2004 | 10:56 PM
97Z-M6's Avatar
avg: cfm intake 200
avg exhaust 145.5
lift int exh
.0500 36.5 27.0
.1000 67.4 50.6
.1500 104 78.7
.2000 138.6 166.2 ??? this must be a type O
.2500 167.4 128.0
.3000 194.4 144.5
.3500 224.3 156.5
.4000 245.0 167.3
.4500 259.7 174.1
.5000 268.6 180.7
.5500 273.7 186.3
.6000 276.4 190.2
.6500 277.4 192.5
.7000 274.2 194.4
i have to say there pretty good. i like the mid lift numbers
any other opinions.
Old Aug 27, 2004 | 11:47 PM
LameRandomName's Avatar
Re: got my heads form loyd today heres the flow #s
89/86 percent of max flow at .400"...
Nice.
Old Aug 28, 2004 | 12:43 AM
97WS6SCharged's Avatar
Nice. Got a cam figured out yet?
Old Aug 28, 2004 | 03:31 AM
97Z-M6's Avatar
yes i do have a cam picked out. ots a joe O custom for a 388. cola crank lunati promod rods and je pistion. and we are going to shift a 6800 in a six speed. ought to be fun
Old Aug 28, 2004 | 03:37 AM
Sounds like it. Why the 388 instead of a 383 or 396? Just curious.
Old Aug 28, 2004 | 09:39 AM
97Z-M6's Avatar
well the 388 is five exta cubes and the only difference is the 3.8 stroake vs the 3.75 stroke. and the longer stroke will create a little more torqe. the parts are alot more for a 396 as well. acctually this engine is built with over kill parts as far as my needs go. but i would rather buy higher quality parts, instead of trying to get by with the bare minium i would need. and who knows i may change my mind and spray 200 shot, and with the parts im using i wouldnt be scared at all. but honsetly im a NA person at heart. but i have been known to change my mind.
Old Aug 28, 2004 | 09:44 AM
Mindgame's Avatar
6800 in a 388? Making power to 6800rpm or just shifting there (beyond peak hp)?
Must be a stout cam.
-Mindgame
Old Aug 28, 2004 | 10:49 AM
97Z-M6's Avatar
i want to make power to about 6700 6800 and shift at 6900 or 7000. but loyd told me joe could make a cam that could do. and i will have to bottom end to do it on so.
Old Aug 28, 2004 | 11:03 AM
F(ast)-body's Avatar
my intake #'s are similiar to those but my exhaust is a little higher...what's the relevance of that?
Old Aug 28, 2004 | 12:37 PM
97Z-M6's Avatar
what are your flow #s. just curious.
loyd said mine are about 5 cfm higher than usual acrros the board. but it really counts from .200 to .400. the better the mid lift #s the better the heads.
edit
i forgot to say that i used 2.05 valve with new seats.and thats why the mid lift #s are so good
Old Aug 28, 2004 | 12:45 PM
Mindgame's Avatar
Sounds good, but let me say this... if you're going to shift at 7k anyway, why not just use a cam that will peak at that rpm?
If you make peak at 6600-6700 then you're giving up power. Spin it 300-400rpm higher and you may see 15-20 more hp. So you shift AT peak hp, but you're still carrying more torque and hp at the shift point.
-Mindgame
Old Aug 28, 2004 | 01:25 PM
97Z-M6's Avatar
-Mindgame
when this motor is done i wont mind spinning it to 7000 at all. but we will see what joe does with the cam. what im going to do is let him know what i want and let him do the rest. and if it peaks at 6700 thats fine. ill let him do his thing since he knows what hes doing. but i will be sure to tell i would like to dhift a 7000,
but i thought you suppose to shift about 300 to 400 passed peak and the stock pcm is only good to 7000.
Old Aug 28, 2004 | 03:16 PM
96speed's Avatar
I shift where my motor tells me too (according to ET/mph). Tell your goals to Lloyd/Joe and let them advise you. That's why ya pay them the big bucks .
Ryan
Old Aug 28, 2004 | 05:04 PM
Mindgame's Avatar
Right. Best shift points require a little numbers crunching and a good deal of track time.
-Mindgame
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
StngStlkr
Sep 6, 2002 05:47 PM
