Got my GM LT4 LE2 Flow #'s
Old Nov 28, 2005 | 01:03 AM
RedLT4Mike's Avatar
Just got my flow #'s from Lloyd on my GM LT4 heads!!!
.200 136/108
.300 194/139
.400 238/168
.500 273/183
.600 285/195
.650 286/201
This is on the stock LT4 Valves
I can't wait to slap em' on the 383 and get this baby going!
Thank you Lloyd! You are a true Cylinder Head Artist!
-Mike Smith
Old Nov 28, 2005 | 01:19 AM
Z-RATED94's Avatar
Re: Got my GM LT4 LE2 Flow #'s
Lloyd does nice work doesn't he. I know you can't give exact specs but give us a rough idea about the cam, if you will? Any hopes as far as track times or dyno numbers?
Old Nov 28, 2005 | 01:33 AM
RedLT4Mike's Avatar
Well, I'm going to be running a mid-sized Joe O. Cam that I purchased before getting the heads done. It's a proven performer!
I'm hoping for at least 420/420.
Who know's....Everyone's setup is a unique animal!
Old Nov 28, 2005 | 02:03 AM
Z-RATED94's Avatar
Now that really is a "rough" idea of the cam specs. I personally am shooting for 400/380 on the stock shortblock this spring before moving on to a larger cam. Which I guess would be a mid size Joe O. cam. That's if he'll do me the honer once again.
Old Nov 28, 2005 | 06:42 AM
hallbilly's Avatar
awesome numbers man... Killer set of heads! Cant wait to see some numbers from those.
I wonder if Lloyd can get 300 out of some LT4's?
Old Nov 28, 2005 | 06:56 AM
AdioSS's Avatar
West South Central Moderator
300cfm from LT4s is easy.
You will get better numbers from stock valve LT4s than you will fromstock valve LT1s every day of the week. 2.00/1.55 valves are bigger than 1.94/1.50 valves and the LT4 ports are better to start out with.
Old Nov 28, 2005 | 12:15 PM
RedLT4Mike's Avatar
I'm sure a bigger set of valves would free up a a few more
cfm. 300cfm from these heads probably wouldn't be out of the question with
bigger valves.
Old Nov 28, 2005 | 12:21 PM
sssalah's Avatar
With 2.05/1.6 valves Lloyd sqweezed out 305 cfm from my LT4 heads.
Old Nov 28, 2005 | 05:04 PM
engineermike's Avatar
300 cfm is not easy from any 23 deg, standard port location heads. If you think it's easy, your flowbench is "happy".
Old Nov 28, 2005 | 07:54 PM
1racerdude's Avatar
Got 330 ish out of mine.
Old Nov 28, 2005 | 09:10 PM
SS MPSTR's Avatar
I tend to agree here.
Old Nov 28, 2005 | 11:24 PM
RedLT4Mike's Avatar
Easy? No, but with some hard, skilled, work, it is
not out of reach.
Old Nov 29, 2005 | 02:21 AM
5.0THIS's Avatar
Stock castings? If so, you're dreaming, or rather, your flow bench is dreaming.
Old Nov 29, 2005 | 02:28 AM
1racerdude's Avatar
Now you don't know what ya are talking about.
Did I say stock castings. The question was 23* stuff.
Old Nov 29, 2005 | 06:00 AM
not out of reach.
I think this should say "with many, many hours on the flowbench, highly skilled work, and a very large intake valve (i.e. 2.08"), you can sometimes break 300."
