got my car scanned
Old Feb 19, 2004 | 09:31 AM
1mostlystockz28's Avatar
got my car scanned
i got my car scanned last weekend and he came back saying that my maf is bad? i dont understand all the wires are intact. do these things just burn out out of the blue. and the computer was confused from the msd 6al i have on there. he said it couldnt quite keep up. any thoughts about the maf would be appreciated. and what kind of maf should i go with if i need to replace it?
Thanks Jason
Old Feb 19, 2004 | 09:40 AM
slider's Avatar
What code(s) did you get?
Old Feb 19, 2004 | 09:56 AM
i dont know the actual code numbers but the maf and tach wire were messed up
Old Feb 19, 2004 | 10:00 AM
TransAm219's Avatar
I had my car scanned one time and it showed a bad MAF and it turned out to be the POS hypertech power modual that was fuggin up the computer . Nothing was wrong with anything on the car
Old Feb 19, 2004 | 11:22 AM
Yes, the MAF can "fail" out of the blue. It can also be a problem with a bent pin in the harness connector, or some cars will damage the pink wire to the harness that supplies +12V from the fuse panel. For starters, take the MAF connector off, turn the key on and see if you have +12V on the pink wire.
Not sure what he is talking about as far as the computer being confused, the MSD "couldnt quite keep up.", and problems with your tach wire. I seriously doubt that the PCM can even tell the MSD is there. Did he possibly get DTC 99, tach output circuit? I've never seen an MSD cause this kind of problems.
Old Feb 19, 2004 | 11:35 AM
Lower's Avatar
I had a bad MAF code once, and it was just the connection going to the MAF. I replaced that pigtail connection, and that solved the problem.
Old Feb 19, 2004 | 01:39 PM
i dont know about the msd he said that the 3 sparks for every 20 degrees rotation it was confusing the computer and sending the ses light off. any more help will be appreciated.
Thanks Jason
Old Feb 19, 2004 | 03:09 PM
BUBBA's Avatar
I wonder if its because you modified your MAF?
Old Feb 19, 2004 | 04:05 PM
Thanks Jason
There is no problem running the MSD box.... the PCM can handle it fine... mine did for 5 years. There are probably hundreds of members here running MSD 6-series boxes with no problems.
Get the exact code(s).
Old Feb 20, 2004 | 09:34 AM
he did say something about me descreening it could of defected it somehow
Thanks Jason
Old Feb 20, 2004 | 02:22 PM
Taking the screen out, assuming you didn't damage the sensor elements while you were remiving it, will simply screw up the calibration a little, but not enough to throw a code. It is possible a chunk of something made it past your air filter?
Old Feb 20, 2004 | 02:43 PM
maybe i mean i havent cleaned the filter for about 6 months. so maybe i appreciate your help guys keep it coming
Thanks Jason
jayblev95
Jan 20, 2015 01:30 PM
brentbrowning01
Dec 16, 2014 06:35 AM
Injuneer
Dec 15, 2014 09:36 AM
USAirman93
Nov 24, 2014 03:37 PM
Brent94Z
Mar 21, 2002 04:44 PM
