Got it dyno'd, am I getting vavle float (graph inside)
Old May 23, 2005 | 09:35 AM
  #16
truedualws6's Avatar
Re: Got it dyno'd, am I getting vavle float (graph inside)
Originally Posted by speed_demon24
Does anyone have the whole part # for the 618 behives, I cant find them on compcams website.
Here are the part #'s:
26918 springs
795-16 steel retainers (10*)
or 794-16 titanium retainers (10*)
614-16 locks (10* +.050")
4705-16 spring seats
On a stock aluminum LT1 head this setup should
result in about a 1.75" installed height. You may
want to send Bret/SStrokerAce an email. He can
probably get you the parts at a good price.
Old May 23, 2005 | 10:00 PM
  #17
toegead93's Avatar
I belive you can use 7 gegree hardware as well (so I've been told):
Comp 648 locs
Comp 787 retainers
stock seats
installed height= ___?(maybe someone can fill in the blank here)
Old May 23, 2005 | 10:05 PM
  #18
SStrokerAce's Avatar
Problem is locks are harder to get....
Bret
Old May 23, 2005 | 10:10 PM
  #19
toegead93's Avatar
What do you mean "harder to get.."?
Old May 23, 2005 | 10:13 PM
  #20
The installed height on the 7° stuff is harder to get right when using stock valves. You need locks that fit the retainers AND raise the installed height.
Bret
Old May 23, 2005 | 10:23 PM
  #21
markinkc69z's Avatar
Nearly every ti retainer I have used increases installed height as well. Many large diameter Comp retainers raise installed height .080". I have no experience with the nickle sized beehive ones, but they may help installed height as well. Of course if you're using ti retainers, you're probably using 10deg locks, and have a + .050" option so the point may be moot.
Old May 23, 2005 | 10:31 PM
  #22
I have spent hours installing and uninstalling both the 7* and 10*
hardware with the beehive retainers on stock heads. As Bret says,
the only way to go is with the 10* super locks (+.050" is preferred).
The installed height of the 7* hardware is higher than the 10* if you
use the regular locks, but only by about .030". Going with the +.050"
locks gets you another .015" to .020" in installed height, which only
gets you in the 1.75" range with a .062" seat.
The 10* retainers (reg and ti) install at the exact same height, it's the
locks that make the difference.
I hope that all made sense?
Old May 23, 2005 | 11:26 PM
  #23
Mark, never seen the Ti beehive ones help.
Bret
fift5
11
Oct 1, 2015 10:31 AM
autoxr166
Sep 25, 2015 04:21 PM
Daluchman1974
Sep 11, 2015 06:12 AM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
