Got the car dynoed....
Old May 8, 2004 | 01:37 PM
CamaroBoy96Z28's Avatar
Went up to Livernois to take advantage of the $50 for 2 pulls on their new Mustang Dyno during their open house. Came away with these results:
260.9rwhp@5000 RPM
294.7rwtq@3000 RPM
All mods are in the sig. I dont know if I should be horribly dissapointed or if its not so bad. I'm assuming the numbers are STD since they just did power pulls with no a/f or anything.
Old May 8, 2004 | 01:41 PM
ibanez6rg's Avatar
Mustang Dyno's give you "real world" results compared to some others. That's why you may be a little low.
Old May 8, 2004 | 01:44 PM
Xride's Avatar
depends on the mustang dyno model though.
should be much higher then that though, my stock was 270 and 305 on a dynojet. (SS, so cold air and exhaust)
Old May 8, 2004 | 01:55 PM
flyinZ's Avatar
If I remember right, the Dynojet's #'s are about 15% higher than the Mustang Dyno...
Not too bad though...What about a tune?
Old May 8, 2004 | 01:56 PM
madwolf's Avatar
It does sound low since you have Hooker LTs, but it's a Mustang dyno. Next time, take it to a DynoJet with AFR readings.
Does the curve look pretty smooth?
Old May 8, 2004 | 02:04 PM
Yeah the curve looks very smooth. I know that the Mustang Dyno would yield lower numbers than a Dynojet but I wasnt expecting that low. I believe it was a Mustang 1750 Dyno.
Old May 8, 2004 | 02:08 PM
madwolf's Avatar
Yea, it's the dyno then. I was thinking that you may have had some knock retard or ignition problems... A tune will also help since I bet you're running rich at WOT.
Old May 8, 2004 | 02:11 PM
Greg Banish from the former Detroit Speedworks was operating the dyno and he said it seemed like I was getting a little knock in the 5kRPM area on the base run but none on the second run.
Old May 8, 2004 | 02:32 PM
madwolf's Avatar
Knock retard will show as zig-zagging on the curve.
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
