Got to ask "what do you think it will run?"
Old Mar 26, 2004 | 08:47 AM
Spanky94's Avatar
Well, what do you think my car will run. I just got it together and can't get to the track for a couple of weeks so I'm interested in what you guys think it might run?
1995 Z-28 A4
383 10.5 to 1 compression
LT-4 Hot cam kit
LT-4 knock module
LT-4 timing kit
Stock heads with minor porting 2.00 intake 1.56 exhaust
Yank 2600 stall
Meziere electric water pump
1 3/4" Jet hot long tubes
3" piping into Flowmaster
No Cat
all smog removed
58 MM throttle body
K&N cold air intake
Ported MAF
MSD coil
Taylor plug wires
NGK TR55 plugs
Trick flow air elbow
275/40-17 BF drag radials
Custom PCM tune
Still have stock rear end with 3:23 gears
I also have a underdrive pulley but it's not installed yet.
I'd also like to know what gears you guys think I should get?
Old Mar 26, 2004 | 09:05 AM
teke184's Avatar
my first thought...
"Traction? who is this traction you speak so comonly of?"
with stock suspension you'll have a hard time hooking.
but with that kind of build up it could run anywere from 11s to 13s...lol
most guys with autos stick with 3.73 gears
Old Mar 26, 2004 | 09:49 AM
lt1g3n's Avatar
that head porting is gunna bring you up there if indeed it is ported much at all.
Old Mar 26, 2004 | 10:35 AM
badblackta's Avatar
You might want to start thinking about some slicks and a 12 bolt
Old Mar 26, 2004 | 07:03 PM
Spanky94's Avatar
going to be going with a moser 12 bolt, and some slicks. That way when I do my engine upgrade it can take it.
Old Apr 4, 2004 | 02:08 PM
Spanky94's Avatar
Ok, ran it today heres what it did.
Run #1
60' 1.876
330' 5.222
1/8 7.974
MPH 89.04
1000' 10.372
1/4 12.395
MPH 111.74
Run #2
60' 1.866
330' 5.206
1/8 7.965
MPH 88.95
1000' 10.365
1/4 12.400
MPH 110.55
Run #3
60' 1.812
330' 5.1.65
1/8 7.927
MPH 88.89
1000' 10.332
1/4 12.385
MPH 109.55
I going to install 3:73 gears, underdrive pulley, subframe connectors, torque arm, and 15 X 10 pro stars with ET Streets. What else can I do to make it to the 11's with bolt ons?
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
