Got to ask "what do you think it will run?"
Well, what do you think my car will run. I just got it together and can't get to the track for a couple of weeks so I'm interested in what you guys think it might run?
1995 Z-28 A4
383 10.5 to 1 compression
LT-4 Hot cam kit
LT-4 knock module
LT-4 timing kit
Stock heads with minor porting 2.00 intake 1.56 exhaust
Yank 2600 stall
Meziere electric water pump
1 3/4" Jet hot long tubes
3" piping into Flowmaster
No Cat
all smog removed
58 MM throttle body
K&N cold air intake
Ported MAF
MSD coil
Taylor plug wires
NGK TR55 plugs
Trick flow air elbow
275/40-17 BF drag radials
Custom PCM tune
Still have stock rear end with 3:23 gears
I also have a underdrive pulley but it's not installed yet.
I'd also like to know what gears you guys think I should get?
1995 Z-28 A4
LT-4 Hot cam kit
LT-4 knock module
LT-4 timing kit
Yank 2600 stall
No Cat
all smog removed
58 MM throttle body
K&N cold air intake
Ported MAF
MSD coil
Taylor plug wires
NGK TR55 plugs
Custom PCM tune
my first thought...
"Traction? who is this traction you speak so comonly of?"
with stock suspension you'll have a hard time hooking.
but with that kind of build up it could run anywere from 11s to 13s...lol
most guys with autos stick with 3.73 gears
Ok, ran it today heres what it did.
Run #1
60' 1.876
330' 5.222
1/8 7.974
MPH 89.04
1000' 10.372
1/4 12.395
MPH 111.74
Run #2
60' 1.866
330' 5.206
1/8 7.965
MPH 88.95
1000' 10.365
1/4 12.400
MPH 110.55
Run #3
60' 1.812
330' 5.1.65
1/8 7.927
MPH 88.89
1000' 10.332
1/4 12.385
MPH 109.55
I going to install 3:73 gears, underdrive pulley, subframe connectors, torque arm, and 15 X 10 pro stars with ET Streets. What else can I do to make it to the 11's with bolt ons?
Run #1
60' 1.876
330' 5.222
1/8 7.974
MPH 89.04
1000' 10.372
1/4 12.395
MPH 111.74
Run #2
60' 1.866
330' 5.206
1/8 7.965
MPH 88.95
1000' 10.365
1/4 12.400
MPH 110.55
Run #3
60' 1.812
330' 5.1.65
1/8 7.927
MPH 88.89
1000' 10.332
1/4 12.385
MPH 109.55
