Goodyear hi-miler hoses?
Old Feb 4, 2010 | 02:18 PM
NewbieWar's Avatar
anyone ever used these?
http://www.summitracing.com/parts/GTR-5006/
Supposed to be longer lasting than generic hoses?
Old Feb 4, 2010 | 03:19 PM
MysticBowtie's Avatar
I've seen them used on a couple of guys cars, but I went OEM because that blue always looks damned ugly after a few miles. I'm kind of a clean freak under my hood though....
Old Feb 4, 2010 | 04:44 PM
neil350's Avatar
Seen some on an Impala, they would be ok if they weren't blue.
Old Feb 4, 2010 | 07:35 PM
chevy94c's Avatar
Is there a differance between the hoses for the 94 to 95?
Old Feb 4, 2010 | 07:38 PM
RamAir95TA's Avatar
I had those hoses on my third gen, and they looked terrible after a few months.
Old Feb 5, 2010 | 12:40 AM
NewbieWar's Avatar
I thought it would make the bay look a little better, but if they change colors, thats probably not a good thing...
Old Feb 5, 2010 | 12:52 AM
NewbieWar's Avatar
anyone ever used the "Samco" Radiator Hoses?
heres a link
http://www.vividracing.com/catalog/s...7-p-15041.html
a bit pricey but come in 7 colors(including black)... for just 4 hoses $192...
probably end up going OEM, but just wondering if anyone had better luck with these maintaining their color, quality?
Old Feb 5, 2010 | 06:08 AM
koolaid_kid's Avatar
I never saw the Samco, but I took a serious look at the hi-miler set, b/c they had everything. But I kept loosing my lunch when I looked at the color. I ended up getting Goodyear hoses piece by piece from Summit. They carry most, if not all of them, you just have to select each one at a time. Boring black, but I trust the Goodyear brand, they were reasonably priced, and it was "one stop shopping".
Old Feb 5, 2010 | 04:30 PM
wbacall's Avatar
I have used them for years, they are very good hoses.
Old May 28, 2010 | 01:54 PM
z28beast's Avatar
ok so will the kit posted above work on a 1994 camaro? i cant find one for a 94!
Old May 28, 2010 | 04:23 PM
93-94 have one hose configuration, and 95-97 have a different configuration. The difference is due to the way the steam pipe from the back of the heads is routed. On the 93-94 cars it goes directly to the radiator. On the 95-97 cars, it goes to the throttle body first.
Shoebox has the hose routing diagrams - compare these and you will see the differences:
http://shbox.com/1/93-94_hoses.jpg
http://shbox.com/1/95-97_hoses.jpg
I suspect its the complex part #14 that has made them avoid making a set for the 93-94 cars.
Old May 28, 2010 | 11:22 PM
z28beast's Avatar
ok well since i cant get the kit...what hoses would you recommend i change? i wanna change as many as possible since my brand new engine and opti will be installed soon
Old May 29, 2010 | 09:20 PM
wbacall's Avatar
The work fine on a 94 as long as you have done the throttle body bypass.
Old May 30, 2010 | 01:03 AM
z28beast's Avatar
which is what? pulling the two tb collant hoses and connecting them via a barbed fitting?
Old May 30, 2010 | 08:49 AM
If you put a 95-97 hose set on a 94 you would cap off the side-out connection of the "tee" in the heater return hose (that where the throttle body feed attaches) - see link below - and - looking at the 95-97 radiator hose routing diagram - you would connect hose #13 directly to point #6 on the steam line. Or just keep the hose you currently have that connects the steam line to the radiator (#4 in the 93-94 radiator hose diagram).
93-94 heater hose diagram, from Shoebox:
http://shbox.com/1/heater_hoses_93-94.jpg
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
