Good replacement fan for LT1 Z?
Old Sep 18, 2006 | 07:37 PM
indirocz28's Avatar
I am looking for a good replacement fan(s) for my 94 m6 z28. The stock fans just dont seem to flow enough. What is a good replacement? and how many CFM should i look for?
Thanks!
Old Sep 18, 2006 | 07:40 PM
neil350's Avatar
Re: Good replacement fan for LT1 Z?
I believ Spal (sp) has a replacement fan, stock dual fans do good though. They usally arent the problem with a car running hot. After a 160 T-stat & PCM4less tune my LT1 runs no hotter than 160*. This is comming from a car that use to run 225+ all the time.
Old Sep 18, 2006 | 07:44 PM
indirocz28's Avatar
Well mine has a tune for 160*, but if i put a 160* thermo in it it over heats. so i run a 180* - and when the car does run hot it gets to about 215*.
My problem is that only one fan runs- and since i dont have the AC hooked up the other doesnt kick on- EVER, so i hotwired the secondary fan to the other fan ( b/c the #1 fan is hotwired to come on w/ ignition.) but it blows relay's all the time and i cant find replacement relays
Especially at Autozone.
Old Sep 18, 2006 | 08:21 PM
RE AND CHERYL's Avatar
Souds like you need to resolve electrical issues, not replace the stock fans.
Old Sep 18, 2006 | 09:18 PM
Severous01's Avatar
stock setup is good for about 600hp...you shouldnt have cooling issues unless you need to replace something like the pump or drain/clean the radiator. if you havent cleaned it out now's a good time to replace the coolant...it does go bad too. it gets scale and buildup just like anything else. i wouldnt run any of the coolant flush systems, just water until the water comes out clean...go both directions, go from the t-stat and from the lower block outlet. check all the lines for spongy feeling or soft rubber feeling...replace the t-stat...it's only about 10 bucks. try running some wetter or purple ice.
Old Sep 18, 2006 | 09:24 PM
indirocz28's Avatar
I've already flushed it man, its clean. the thermostat in is less than 2 mos old. it doesnt over heat, and it only runs warm on hot days or on long trips. I was just wondering if there was anything i could do for my fans. the secondary fan doesnt seem like it pulls as much air through as the #1 fan. there is nothing blocking them or anything, it just seems like it doestn pull as much. When i had just the 1 fan on the car never blew a relay, but now i have the 2 on and it blows the relay- i suppose i need to hotwire the 2nd fan circuit just like the 1st fan, then i probably wouldnt have a problem huh?
indirocz28's Avatar
indirocz28's Avatar
Old Sep 18, 2006 | 09:55 PM
huskersZ's Avatar
sounds to me like you have other cooling issues and it isnt the fans. When driving, enough air should get thru the radiator, so the fans arent even needed. You said it overheats on long trip, so sounds like you have other issues
Old Sep 18, 2006 | 10:10 PM
Only one fan runs because your engine is not getting hot [215°]. The second fan would not be commanded on at that low of a temperature (I assume you have a 2 relay system). Also, a 160° thermostat should not make it run hotter. Something wrong there. Your relay problem may be due to your "creative" wiring to make the other fan come on.
I don't think replacing fans is going to solve your problems.
Old Sep 18, 2006 | 10:40 PM
indirocz28's Avatar
It may not, but the # 1 fan was already "creatively" wired like that, i only wired the 2nd fan to it.. - its not like its overheating or anything, i was just wondering..- but for real though- it will overheat if i put the 160 back in..thats wierd as hell..
Old Sep 18, 2006 | 11:02 PM
Dave89IROC's Avatar
is the 160 a LT1 style t-stat, not a regular sbc one?
Old Sep 19, 2006 | 06:55 AM
I would put the wiring back to stock and start from there.
Old Sep 19, 2006 | 12:45 PM
TobyZ28's Avatar
If you want to change when your fans go on / off the right way would be to edit the computer file. Is your airdam scoop on under the car? this will cause it to run hot on the highway.
Old Sep 19, 2006 | 01:45 PM
indirocz28's Avatar
well according to Advance it was for the 94 LT1 sbc.. but it was from Mr. Gasket when i got the package so i dunno. it may not have been...
Whats a good brand of one to buy for it?
Thanks!
oldschool
Feb 9, 2016 09:21 PM
4586
Dec 31, 2014 02:21 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
