Good Price on LT4 Heads?
Old Feb 9, 2004 | 09:44 AM
  #16
MaddHatter's Avatar
Originally posted by BadBirdLT1
One thing to remeber N20 is never safe it can always screw up and tear up your motor. If you run a wet kit and the nitrous bottle has to much pressure and is spraying more nitrous than normal and you aren't supplying enough fuel say good by to your motor.
What I am trying to say is Nitrous is like a hot chick with an STD you know you want to hit it but you dont want the consequences.
So Forging internals is like wearing a condom...? it can always break on you and then you're ****ed... what are some other preventative measures for a NOS setup? Should I stick to a 75-150 shot to be "relatively" safe?
Old Feb 9, 2004 | 09:48 AM
  #17
BadBirdLT1's Avatar
The lower the shot the safer you are.
Kinda like STDs
AIDS= 300 shot (your dead)
Gonareha= 250 shot (your screwed)
Syphliss= 200 shot (your screwd)
100 shot= Clamydia (easy fix with penicilinn) No I have never had an STD just know this stuff.
See the lower the shot the less a chance of destruction but also if something does go south with a smaller shot maybe you'll just smoke a piston and not your whole motor.
Old Feb 9, 2004 | 09:51 AM
  #18
MaddHatter's Avatar
so what's Herpes? 150 shot?
Old Feb 9, 2004 | 09:58 AM
  #19
BadBirdLT1's Avatar
Damnit I knew I forgot one of the Shots.
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
