Good Pininon Angle?
Old Dec 26, 2003 | 05:02 PM
Mid-life Toy's Avatar
Good Pininon Angle?
What is a good pinion angle for the street? Should there be a different pinion angle setup for the strip? Does it matter if you have a stock rear or a 12 Bolt? Does the transmission type make a difference, i.e., manual or automatic?
What is the best gauge to use to measure pinion angle?
A safe New Year to everyone!
Cheers!
Old Dec 26, 2003 | 06:22 PM
revtime's Avatar
My BMR TA came with a pinion angle finder tool.
From what I have read the autos like -2 and the manuals as much as -4, I am running -2 in my auto on the street but its not a daily driver. 0 is reccomended for regular street driving and then adjust at the track but I have been driving mine with -2 on the street for 5k without any problems.
Too much negative or positive angle will shorten U joint life and in extreme cases I would think it might even cause binding.
Stick with between 0 and -2 on an auto or a manual for that matter but with the stick you could experiment at the track with more negative angle to see how the car reacts.
Old Dec 26, 2003 | 08:26 PM
OBE1 95Z28's Avatar
I would suggest zero pinion angle for the street. Street tires aren't going to hook causing your rearend to rotate and as stated above, you're just working your u-joints over.
oldschool
Feb 9, 2016 09:21 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
thenewkid
Nov 27, 2014 09:41 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
