Good oil filters?
Old Nov 24, 2004 | 09:07 AM
IrocManiac's Avatar
Good oil filters?
What's good, whats bad? Does it really make a difference if you're changing it every 3 to 5k miles?
edit: I maybe should have posted this in the general forum, but I do have an LT1 car so I dunno....
Old Nov 24, 2004 | 09:20 AM
GREGG 97Z's Avatar
Re: Good oil filters?
Best - K&N HP-2002 or the 3002 (longer version) price $9-10 ea. Or the Mobil 1, (rumored to be the same thing as the K&N just different label)
Worst? - Fram. Glued on paper end caps for one thing, I've heard many stories of them failing.
For a daily driver changing oil every 3000 or so the AC delcos are a very good filter for the price.
Since I change my oil once a year or every 3000 miles anymore and race it most of that time I spend the extra $5 for the K&N. Its a sweeeet filter
Old Nov 24, 2004 | 10:14 AM
mebanditws6's Avatar
The m1's are not the same as the K@N's. They filter a little better but don't flow nearly as well. You want flow if you drive your car hard alot because the filter won't have to switch into bypass mode as often. Plus the K@N's have that 1" nut on the bottom to make removal alot easier on our cars where a regular wrench gets kinda awkward.
jason
Old Nov 24, 2004 | 10:36 AM
Amped96's Avatar
I run an AC Delco 1218 and am have always heard good things about AC filters.
Old Nov 24, 2004 | 10:41 AM
ejfagala's Avatar
K&N is a great filter but a little more $$$$, Wix is good filter as well.
Here is a good link to some testing done:
http://www.scuderiaciriani.com/rx7/oil_filter_study/
Old Nov 24, 2004 | 11:38 AM
anaik's Avatar
Here's another link. Scroll down.
http://theoildrop.server101.com/ubb/ultimatebb.php
Old Nov 24, 2004 | 11:47 AM
rskrause's Avatar
Moderator
I've been using AC Delco for YEARS and have no complaints.
Rich
Old Nov 24, 2004 | 12:12 PM
TobyZ28's Avatar
I use the oversized ACDelco filter and have been very happy with it for the last 2 years or so. You can get the stock size or a slightly bigger size thats used on the corvettes. I highly recommend them.
Old Nov 24, 2004 | 12:24 PM
GREGG 97Z's Avatar
jason
I've not used the M1 filter, like I said I just heard they were the same, I guess they arent. Sounds like the K&N is the better choice though so thats good. Oh, and that 1" nut on the K&N is worth the extra $5 alone
Old Nov 24, 2004 | 12:44 PM
fuzzyz28's Avatar
my last oil change I switched to AMSOIL...both filter and oil just becuase a friend of mine is now a dealer.
However, prior to that I've used the Fram duragaurd...for the past 8 years without any issues, along with MOBIL 1 oil.
Old Nov 24, 2004 | 12:52 PM
Bersaglieri's Avatar
The best is K&N, but since Summit sometimes wont stock it for LT1's, I use Napa's Gold series or AC Delco.
-Dustin-
Old Nov 24, 2004 | 01:01 PM
94Zpower's Avatar
I use the K&N HP-3002 and notice that my oil stays cleaner longer, I think they are worth the $.
Old Nov 24, 2004 | 02:03 PM
GREGG 97Z's Avatar
-Dustin-
Pep Boys carries the K&N HP 2002 & 3002 on the shelf around here, for $9.99.
Old Nov 24, 2004 | 02:14 PM
Ah, I'll have to check into that, not many Pep Boys around here, but I'll have to find one now, thanks!
-Dustin-
Old Nov 24, 2004 | 02:54 PM
CamaroBoy96Z28's Avatar
AC Delco PF454 every 3k here.
