Good nitrous rings?
Good nitrous rings?
Ok, plan on doing a stock bottom end rebuild this summer with a cam and wanna continue to spray a 125 shot on it. This is just a cheap rebuild while I save for the forged 383 with a D1 I wanna get later on down the road. Just wondering if this is a good set of nitrous rings or if someone has some better rings for a stock piston.
http://store.summitracing.com/partde...5&autoview=sku
The stock ring set is very good. The top ring is plasma moly.
The rings you show in the Summit link are not 2mm 1.5mm and 4mm like stock.
Here is a link to some Sealed Power stock replacement rings at Summit,
LINK to Summit
That's the size for stock piston rings. Local parts store can order those or Hastings #2M2646 STD.
Karl
LINK to Summit
Karl
Fbodfather
25
Jun 21, 2002 04:12 PM
