Good cam to work with LE2 heads
Old Mar 30, 2008 | 04:13 PM
9formula4's Avatar
I am set on a set of LE2 heads (sending mine to him) and was looking at the description of the cam and would like to know if anyone has found a cam that works well with this head setup. I would like to have something that is making power from 1500-1800 all the way to 5500-5800.
Any suggestions??
Old Mar 30, 2008 | 04:39 PM
z28_theantirice's Avatar
Talk to Lloyd, he would be your best bet!
Old Mar 30, 2008 | 05:05 PM
dangalla's Avatar
yeah is there any reason you dont want to go with the le2 cam. it does move the powerband up slightly from what you want.
Old Mar 30, 2008 | 06:35 PM
2000GTP's Avatar
Yeah, if you are going to have the heads done by him, you might as well have him set you up with a cam as well for your specific needs.
Old Mar 30, 2008 | 06:37 PM
mdacton's Avatar
do your homework, if you don't understand what you have or how to get what you want your just pissing in the wind and throwing money away
Old Mar 30, 2008 | 06:42 PM
kylersaulsbury's Avatar
Yes talk to Lloyd. He is a great guy, and will help you out. What he will probably do is set you up with a custom cam. Im pretty sure he doesn't charge any extra, just the standard $350. That is about the only way you are going to get a cam that makes a decent amount of power for that rpm range.
Just out of curiosity, Why don't you want to rev higher than 5800?
Old Mar 30, 2008 | 06:43 PM
sn8ke eatr's Avatar
le2 cam?..
Old Mar 30, 2008 | 06:47 PM
dangalla's Avatar
if your just want our recommendation i would say for that rpm range you should maybe look at the LE1 cam, but again talking to lloyd is your best bet, he is a very nice guy and will gladly take the time to help you out. i would stay away from the high lift [HL] versions of those cams though
edit: just so you have an idea my cam starts to make good power around 2500 and pulls very strong until i let off at 6600
Old Mar 30, 2008 | 08:43 PM
9formula4's Avatar
I dont rev over 58-5900/A4 car. The car is a street car mainly. I have no reason to go any higher. I want the powerband moved lower and keep the powerband i up through to the shift.
I am doing my homework dacton. That is why I have this thread posted. I have heard of others running cams other than the LE ground cam and was seeing what the suggestions were.
I have seen the cam specs for the LE2 cam and they are spec'd out right but I want the power band to start lower than they do.
I will talk to Lloyd to see what he can do but lets see if any of the non LE cam guys chime in.
Old Mar 30, 2008 | 08:48 PM
kline454's Avatar
cc503..
Old Mar 31, 2008 | 01:00 AM
user 647483's Avatar
Consider an LE1 or LE1.5 cam in that case.
More beef down low and across the board than the off-the-shelf grinds.
Actually Bret will design a cam to meet your needs, whatever they may be for the same price.
At the very least use a modern grind like a CC50x.
Old Mar 31, 2008 | 01:12 AM
slomarao's Avatar
llyod will do whatever you want with your cam. If 6k is where you want to be shifting than just say so. You ll be giving up some power by not reving it high enough but it looks like you could care less.
Old Mar 31, 2008 | 01:31 AM
Z-RATED94's Avatar
Any suggestions??
Maybe you should just use some 1.6 rockers with the stock cam. That should peak right around where you want, going from (1500-1800) to (5500-5800) with those heads and save you some money. Just a thought.
Old Mar 31, 2008 | 01:48 AM
speed_demon24's Avatar
You might want to PM truedualws6 on here, he has a combo similar to what you want to do.
Old Mar 31, 2008 | 07:54 AM
NightTrain66's Avatar
If you are wanting power only to 6000 RPM, a cam in the mid 210 duration to low 220 duration is all you need.
We can make it idle as smooth as you like or even put a lil chop into it depending on emissions and how broad you want the power band (idle to 6000 RPM, 1500 to 6000 RPM, 2000 to 6000 RPM).
Catalog cams like the GM 845, Crane 227, etc, will work well if you do not want a custom cam.
Lloyd
