Good air and a 11.88
Went to the track last Sunday and the DA was almost sea level. Finally improved my motor only times and ran the 11.88 with a 1.59 60ft. time. I thought this was pretty good since I'm fighting a high rpm miss issue. Hopefully I'll figure it out one of these days.
I'm on Eibach Pro lowering springs with stock shocks, so no it does'nt. A friend with a spring compressor is coming over tomorrow and we're going to put the stock springs back on the front. I cut 3/4 of a coil off, so hopefully it won't sit to high in the front. Even on the bottle with a 1.47 60ft. time it does'nt lift a wheel. If I let the air out of the air bag in the right rear it might have a chance, who knows.
Correct, no spray this time. I took some weight out to make up for the 65-70lb. roll bar and figured I would try for some new NA times. The track was packed and I didn't fell like waiting another 2-3 hrs for another run just to use the nitrous. It took almost 2 1/2 hrs. to get home with the construction going on. Maybe next time.
95chwagon
Jan 13, 2015 09:19 PM
