Gonna kill my car!!!!!!!!
Old May 12, 2003 | 02:52 PM
Mr_Superman's Avatar
Angry Gonna kill my car!!!!!!!!
Help someone....
Installed hotcam kit, mac headers, new plugs/wires, !EGR, !AIR on a 94 LT1. My car has NO power. I thought it may be plugs and wires on wrong or somethin but double and triple checked it, not the problem...Next I chased wires all are connected...Then I unplug the MAF sensor and my car still runs the same way.
It is starting easily will idle fine but when under load or acceleration it doesnt wanna go, feels like I'm drivin a Honda. It is missing and I am at a loss...I feel helpless and I am so aggravated I'm gonna shoot my car. Also I can hear like a sucking sound kinda like there is a leak or somethin somewhere....if I miss a plug for the EGR and AIR would it completely rob the power like that? Someone anyone help me!!!!
Is it because it needs tuned???? Gawd help me!
Old May 12, 2003 | 03:22 PM
1997rblckSS's Avatar
the car will run good with the stock program(well you can get away with it). does it pull at all in the higher rpms? the EGR and airpump are only really used at idle, @ WOT they don't really play a factor. Did you install an EGR block off plate on the back of the intake?? but then again, if you didn't install that the car wouldn't hold idle, I have no idea, you make have a vacuum line not hooked up or something,
TTT for ya, maybe someone can pick this up and help you..
Old May 12, 2003 | 03:36 PM
After getting it to start rolling it seems like it is going to start picking up power....not really had it that far to try because I dont wanna get out and break down with it running like this....Anyone and thanks for the reply rblackSS
Old May 12, 2003 | 03:41 PM
joeSS97's Avatar
Are you sure you have the timing gears right?Rockers adjusted 1/2 turn past zero?Did you plug the air on the intake tube and rear of manifold?Check those.
Old May 12, 2003 | 03:45 PM
chikn's Avatar
Sounds like maybe to much preload on the valves or the cam isnt degreed right??
Old May 12, 2003 | 03:53 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
yea, could be very misadjusted rockers.
Old May 12, 2003 | 06:08 PM
We checked the valve lash...ok, cam timing-ok, i'm thinkin all air and egr is plugged off but whjat place are you talkin about on the intake tube? Thanks for the replied, help me get this thing runnin!
Old May 12, 2003 | 06:10 PM
Oh yeah just to double check can someone give me the firing order and where to plug the wires in on the opti spark...I checked the haynes manual and just wanna make sure.
Old May 12, 2003 | 07:12 PM
ttt plz
Old May 12, 2003 | 11:20 PM
come one everyone lets join together and make my car and me happy again!
Old May 12, 2003 | 11:47 PM
SWINGRRR's Avatar
Sounds like what I did to my car. Hotcam does'nt start till about 1800 rpm's or so. Do you have a CAI? That explains the sucking noise. Get a tune. www.pcmforless.com. We were making a video for my club and without the tune did several 120+ mph passses without tune. Car dyno's 260 (stock manifolds) after tune, before exhaust. Will know more after F-body gathering and better tune.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Donwest22
Parts Wanted
Jan 14, 2015 03:56 PM
bernie1951
Dec 10, 2014 10:03 AM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
