Gone through multiple Opti's so need suggestions
Old Feb 1, 2009 | 08:39 AM
95Blackhawk's Avatar
all,
2 engines, 5K miles and about 5 opti's. WTF? I have the vent hoses connected correctly, I confirmed that. one way valve is opening correctly only towards the intake manifold. Filter is in.
I end up with either code 16 or 36 so it ends up being the optical encoder only that is the problem. What am I doing wrong?
Ben
Old Feb 1, 2009 | 09:39 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
What kind of optisparks are you using?
Old Feb 1, 2009 | 09:41 AM
AC Delco direct replacements. However, I have tried the Autzone rotating assy. Yes, they are refurbished at AZ but still should give me good life beyond what I am getting.
Honestly, I am only looking for 5K miles life out of these things since I do race so I am not expecting the world of them.
Old Feb 1, 2009 | 10:00 AM
doug1105's Avatar
check the harness going from the opti to the ECM. Check the pins for damage.
My harness was baked and melted under the corrugated black plastic wire loom protector.
The wires had no insulation in spots. Summit sells a new one for cheap.
Old Feb 1, 2009 | 10:06 AM
RamAir95TA's Avatar
Check the length on the cam dowel pin. If it's too long it will put too much pressure on the rotor when bolted down and fail.
If you've fried 5 opti's then there's definitely common ground somewhere, and that's where I would put my money.
Old Feb 1, 2009 | 11:05 AM
Have new harness already. Thanks for that idea.
Old Feb 1, 2009 | 11:06 AM
Thanks but did this also...for both cams in both engines. Further, you can tell on the wear pattern that the pin is not bottoming out.
Can I have your money now?
Old Feb 1, 2009 | 12:15 PM
DugRat's Avatar
Last time I bought a new opti Dal told me GM won't warranty the opti unless you replace the vacuum harness with it. I bought the new vacuum harness for $15 and it cured my opti problems. I was getting about 5000 miles on one before and now I have gone 50,000 on this one with the new vacuum harness.
Old Feb 1, 2009 | 01:20 PM
Prorac1's Avatar
Also check plugs, wires, and coil for any resistance or arcing. Either could cause the eye to burn out. Eric L
Old Feb 1, 2009 | 01:55 PM
There is a new one! I will do that!
Old Feb 1, 2009 | 01:57 PM
Another one I have never heard of. I will do so!
HectorM52
Jul 30, 2017 11:46 AM
Sergio
Jan 27, 2016 04:27 PM
thenewkid
Apr 12, 2015 07:42 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
